FunkyJive
QuoteThis PPM system in it's current configuration also has a long way to go.
@hydrocontrol
It certainly looks that way so far, and with a few months gone by and so many dedicated constructors seriously working on this project, I get the feeling that at-least something positive (however small) should turn up in that time.
In eager anticipation I'm looking forward to seeing it - particularly as the full working specs of a successful unit can then be shared - with other constructors actively supported to properly verify this motor.
FunkyJive
"Invention has its value, but discovery is priceless"
"Faith from the wealth of negative speculation cannot deny faith from the sparks of promising experimentation"
"A quest of impossible odds is not driven by expectations of what is achievable, but by the certainty of what is not"
"It is not weak minds that perpetrate misconceptions, but strong minds heading in the wrong direction"
"Experimenters seek understanding from achievement, academics seek achievement from understanding, whilst sceptics would seek to deny them both"
"Once the world was flat lest we should fall off. Once man could not fly as he was much heavier than air. And so we arrive at another threshold"
BD Townsend
cub3
@all, AL has already mentioned that the 2 holes were tooling holes to attach to his rotary table.
The now red weight!! he has explained as being a pulley for load / friction tests, look at earlier pictures there is also a bracket and pulley mounted on base plate.
Regards Den.
Omnibus
@cub3,
Yes, I know that. The problem is, is the rotor weight 258g with that red weight or not?
vipond50
Quote from: cub3 on January 28, 2008, 11:02:17 PM
Regards Den.
@cub3
Thank you, its ..... Anyway, i missed this one. i will go back and reread all the post again to see what else i have missed
Daa on me :P
Thx
lumen
Sorry to interrupt the train of thought but I want to show what I believe will work. (at least until I try it and it don't work)  ;D
I will try to build it this week and let everyone know. The main idea is that the little stator magnets can enter at the center of the rotor magnets where they will move in with no force.
Then will exit at the end of the stator magnets again in the center with no force. In the middle they will apply a strong force in only one direction on the rotor.
Is this like ORBO?
