Bruce_TPU
Hello Bill,
Thank you very much for the information.  We are still trying to get our correct size rotors.
I would be interested in seeing your pictures.  Also of your bearing assembly in the base.
And the carved out underbelly of your rotor.
Thank you!
@ All
Has anyone heard any more from Clanzer?
And from Bill's information, once again we see the importance of following the details.  In other words, the weight of the rotor matters!!  So we need to carve out some of the underbelly to match weight, it would seem.
I will weigh my new rotor when it arrives.
Cheers,
Bruce
Omnibus
@All,
Here are some rough data for the magnetic induction at 5mm distance from my rotor (in absence of stators) and stators (each stator in absence of the rest of the stators and the rotor). The hall sensor was positioned at the bottom of rotor magnets and flush with the top plane of the stators.  Although I positioned the sensor immovably with respect to the rotating rotor and stator, I was incrementing the angles by hand. Although much more precise measurements have to be made, especially with regard to the exact angles of measurement one can see at least that the magnetic induction of the stators is almost a magnitude greater than that of the rotor. Qualitatively that's exactly what's required. We, however, need to know the exact data taken as in this example so that we can make quantitative comparisons with the original.
Forgot to mention, all magnets are said to be N42. By the end of the week I'll probably be able to report similar results with the N38 and N35 magnets.
Omnibus
I should add also that the 5mm distance I mentioned is from the sensor to the outside cylindrical surface of both rotor and stators. Therefore, the probe is closer to the surface of the stator magnets than to the surface of rotor. That was the distance @alsetalokin emphasized on. Later in the week I'll carry out measurements with the probe equidistant from the surfaces of the magnets themselves.
vipond50
Ok, Here's a few Pics (8) Should give a pretty good idea.
BTW this is all backup with Cad other than a few recent changes.
Pictures removed because they did not follow the original Specification, what ever that is ? :'(/
B.
vipond50
Quote from: Bruce_TPU on January 29, 2008, 09:31:32 PM
Hello Bill,
Thank you!
@ All
Cheers,
Bruce
O yeah Bruce
i for got to metion that the ABEC - 5 bearing really made a difference to the Stator's stability, shouldbeable to handle the job with a single bearing. Glad U went with the ABEC-7's, should be that much better.
BTW: the ABEC -1 are junk for this application.
@ Omni & All
Go with at least a grade 5 or better yet a Grade 7 bearing when U deside to upgrade your bearings.
