RunningBare
Quote from: Omnibus on January 30, 2008, 05:07:37 AM
Quote from: cub3 on January 30, 2008, 05:02:44 AM
The red Weight is still a pulley!! My point earlier about Observation. And Bill the bracket on Lhs holding other pulley.
The blind lead the blind.
Youre collective egos ignored.
Learn to read.
Den
What is that supposed to mean? That red piece doesn't play the role of a pulley in the video. Or you have evidence that it does? Where is the evidence?
39 seconds into the video http://www.youtube.com/watch?v=2pmrSYV4zFI "The pulley's are for eventual friction testing"
Bruce_TPU
@ Bill,
Please repost your pictures, as I have not yet seen them.  Learn to ignore the rants of others, Bill.
@ Cub
If you want a spreadsheed, etc.. I say if you have the burden, go for it.  Rantings do not assist the effort.
@ All
Bill contributed greatly, proving that the rotor weight does indeed matter greatly.  This is important, to get our rotor weights to the exact weight given by Al.
Does anyone know how Sean's testing is going?
(Our correct sized rotor should be finished Friday and in the mail.  You have no idea how frustrating it has been.  My 6061-T6 alloy arrived yesterday.  I will have it cut and drilled today.)
Cheers,
Bruce
EDIT:
I just weighed my rotor that is 3/8" short of Jason's blue print.  Weight:  258 grams.   ???
