RunningBare
Quote from: vipond50 on January 31, 2008, 07:18:41 PM
Just saw this on ClanZer's Group
Was posted by JustMaybe
Snip:
Having been alerted to the assymetrical rotor magnet layout I did some cad work on the rotor layout, sized the photo to 144mm diameter and took some measurements. Note, due to the fisheye distortion of the camera lens the measurements may be a bit off (13mm long magnets for example), however, the relationships should be the same. In short, the North poles are closer together than the South poles, and may explain why your symetrical layout doesn't self sustain. I haven't time today to change my rig, so please, someone check this out.
JM
Notice how that top stator is oriented wrongly, unless AL marked it incorrectly the black half should be facing the rotor
magnetman12003
Hi All,
Is there any reason Al cant take his original working motor device outside and in "BROAD DAYLIGHT" make a "QUALITY"movie clip of it working on a glass top table. He can start it any way he wishes then let it run and "telephoto it" operating at a distance without standing close to it.  He already claimed he had it running for hours?????
Credibility would then be established. As it is everyone is second guessing and no real working replications have been made as of this date.
Dark movie clips and and a inventor who will not release his true name dont cut it.  My thoughts are he is using the entire world as his final testing lab to see if anyone can get his basic idea really working.
Then he will step forward when thats accomplished by some one else and take full credit.   I see Butch and some others quit trying to replicate it.
Tom
Omnibus
Quote from: Lakes on January 31, 2008, 07:41:08 PM
Just an armchair observer so far (although I am buying some lego to play with as funds allow  :) ), if you remember that Al said that some stator magnet & bearing combinations just would`nt work at all, I assume he referring to acceleration and not just the AGW rotation, might be worth trying?
Yeah, that's what I meant. I'll try later with different combinations. AGW isn't difficult to achieve, it's the acceleration (the effect, that is) we're trying to achieve.
Omnibus
@vipond50,
I tried to place the North poles similar to what's in the pic. Otherwise the diameter is slightly off (by 1-2mm) than what in Jason's drawings.
RunningBare
Quote from: magnetman12003 on January 31, 2008, 08:08:13 PM
Hi All,
Tom
His reason is his schedule, and hes made it quite clear he will not succumb to pressure or demands.
After he initially posted the video he got a lot of that.
You also have to take into account that he specifically says that the video proves nothing and that OU is NOT possible.
He has maintained his stance on this throughout his posts on the steorn forum and FizzX.com.
