vipond50
Quote from: Omnibus on January 31, 2008, 08:16:33 PM
@vipond50,
I tried to place the North poles similar to what's in the pic. Otherwise the diameter is slightly off (by 1-2mm) than what in Jason's drawings.
@ Onmi
Excellent, Glad to here that is is close, Helps confirm that the radius relative.
B.
Omnibus
@magnetman12003,
That's all right, the credit will go to him and to whoever reproduces it. Unless the working device reproduced doesn't follow his specifications.
As for what he says regarding whether or not this is OU that should be ignored altogether. It's not up to him to judge what is and what isn't. I've had prior discussions with him and have determined that his understanding of the subtleties of science is wanting. Let's see the effect shown in the video continuing for 7.5 hours, as claimed, and then see how anybody can deny it's OU.
Bruce_TPU
Hello All,
I have my 6061 T-6 cut drilled and mounted.  New machined rotor is being worked on today.  I hope to be with Bill and Omni, Jason and Hank if a few short days when rotor arrives.
A few thoughts:
Weight of the rotor matters.  Bill showed this by experimentation and just plain logic dictates it.
AGW lock with the rotor is so unique.  Many thought it could just be slapped together and work.  If that were the case, someone probably already would have seen this effect and had a working unit.
So, we must get our rotor's down to the proper weight.  We must also interchange bearings and stator magnets, looking for a working couple.  But I think rotor weight is the first thing to address.
@ Bill
Thanks for posting the rotor measurements from Clanzer's forum.  I will use them with my new rotor, when it arrives.
Let's take our time, and go step by step.  There is no rush.  Accuracy is needed.
@ Omni
I am glad that you found 30.5 mm separation N38's.  Please post the link from where you purchased them.  Thank you.
Cheers all,
Bruce
Omnibus
@Bruce-TPU,
Getting the stator to rotate AGW is no problem at all. Turns out, however, that it's not the solution. @alsetalokin has left the impression that once he made the "mistake" to have the  stator turn AGW, voila, the effect kicked in. Not so.
I'd like to know what the rotor weights of @Craigy's and @CLaNZeR's are. It seemed they had some lighter rotors. I do agree, though, that the rotor weight is a crucial parameter and we have to work on that problem. First, someone has to approach @alsetalokin next week and see if he still can reproduce the effect and if so what the rotor weight is as wel as the magnetic induction profile of the stator and rotor. If he isn't cooperative enough we have to play with various weights and compare notes regarding the magnetic induction profiles.
As for the N38 magnets I got them from http://www.engconcepts.net/List_Of_Cylinder_Magnets.asp. I think they are CYL0175.
vipond50
Quote from: Omnibus on January 31, 2008, 09:02:53 PM
@Bruce-TPU,
Thanks Onmi
I'll order in a batch
B.
