cub3
Quote from: Omnibus on January 31, 2008, 10:57:17 PM
The more I'm looking at my rig the more the old problem seems to be popping up--as many have already said, the weights, especially the rotor weight may be the crucial factor, now that we have the proper magnets (I hope so). Not so much the bearings but the weights and the interplay of the fields due to the mutual disposition of the magnets. But then, again, why didn't @Craigy and @CLaNZeR get positive results with their seemingly lighter rotors. Could it be they were too light? Anybody know what their rotors' exact weight was?
One tends to think that a flywheel effect should be utilized but the flywheel may be just too heavy and won't allow the effect itself to emerge.
ALL,
As previously mentioned.
This place needs a database (spreadsheet of Al's. / and everyones initial & subsequent dimensional & constructional modifications, with a time line showing further changes, results etc. Most important.
Den
vipond50
Quote from: cub3 on January 31, 2008, 11:43:00 PM
ALL,
Den
Hi Den
Well your idea  ;D, which is good , put it together and i am sure others will add or make available the data.
Cheers
B.
PolyMatrix
Check the shadow of the main rotor in @Al's video. the rotor is not in the exact centre. You can compare the shadow distance with the static bits around the outside of the main rotor.
Edit. also looking at the shadow of the centre of the main rotor in the strobed video the same effect can be seen, however would perfer it if someone with better picture analysis would confirm this observation.
cub3
Quote from: vipond50 on February 01, 2008, 12:10:58 AM
ALL,
Den
Hi Den
Well your ideaÃ,  ;D, which is good , put it together and i am sure others will add or make available the data.
Cheers
B.
Of course it is good it should have been implemented at the very start of any replicationor any serious attempt to produce anything.
I am glad you finally see the value, that this will have to this site. Perhaps others will also.
It is not my place to do so, it is the very basics of engineering and science, for THOSE participating to record so that they may reproduce. Am I wrong?
Den
Bruce_TPU
Quote from: PolyMatrix on February 01, 2008, 01:52:47 AM
Hmm....
That is interesting.  Can anyone else confirm or deny this?
