Grimer
Quote from: Spartane on January 31, 2008, 03:28:24 PM
One of the things that Sean mentioned on the Steorn site was the need for "poor quality" magnets.
So maybe Al used older crappy rotor magnets that he happened to had lying around, and the rest of you are using fresh, off-the-shelf magnets that have their magnetic domains so firmly locked into place, that they cannot be modulated by the spinning stator magnet.
Anyway, something to consider...
I think that is a very good point. If one is to generate energy one has to cut a chunk out of the BH loop in the opposite sense from the energy loss (refrigeration) direction. Maybe the change from GW to AGW marks that change in direction. Mmmm.......very interesting. I hadn't looked at it that way before but it's so obvious when you think about it. That is what the change in rotor direction is telling us.  8)
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
Omnibus
I will have to send my rotor to be milled down to 258g so I won?t do experiments till probably Tuesday.  In the meantime I won?t stop discussing theory but not here. Please @Grimer, @Spartane and others who also want to discuss theory would you mind moving to the debate thread to avoid cluttering this thread devoted solely to the technical issues regarding the replication of @alsetalokin?s device.
Yadaraf
Quote from: Grimer on February 01, 2008, 04:12:57 PM
How about crappy supports -- ones that wobble enough to resonate like the Tacoma Narrows bridge [a.k.a Galloping Gertie].
It's possible the new and very "tight" replications are so different from Al's cobbled together original that some natural [and potentially catalytic] resonance (oscillation) has been lost.
Perhaps mounting the stators to someting less rigid -- like hard rubber -- would induce resonance.  Perhaps the same is needed for the rotor.  Studying the resonant frequency (300 rpm ==> 5 cps?) could be useful.  The closest natural phenomenon that comes to mind is the Schumann resonance of 7.8 Hz (~468 rpm).
... Schumann resonance:  http://147.175.143.11/schr-e/index.php
Time to loosen up?  ???
Cheers,
Yada ..
MeggerMan
@All,
Looks like Turbinator on the Steorn forum has achieved sustained rotation, in his last post he sort of implies that he is holding the stator magnets in his fingers which may not be good.
http://www.steorn.com/forum/comments.php?DiscussionID=60264&page=1#Item_5
I hope this works out and become the first independant running replica.
Couple of pages back someone mentioned ceramic bearings, these are available quite easily from r/c model places and ebay, they made from stainless steel, ceramic ball bearings and have a special low friction lubricant.
They last a lot longer, are not effected by magnets, so a good choice I think.
Here is a lightweight bearing I found 5x8x2.5mm:
http://www.modeltech.co.uk/catalog/product_info.php?cPath=102&products_id=478&PHPSESSID=05c675e5dd4ad987c71085cfa21e8733
There seems to be a lot of discusion about critical rotor weight, I would concentrate more on the stator friction if I were you.
You could always mill out a circular slot in the disk if you want to be spot on but I think time would be better spent looking at the major point of friction, that being the stator bearing - it spins faster, has very little inertia and I have seen from my own tests that ball bearing lockup from the stator magnet is a major problem.
I think we are good to go now...
regards
Rob
Omnibus
@MeggerMan,
Did you read one of my latest posts? There I explained that I replaced the bearing with a brand new one. As a result I couldn't latch it in AGW no matter how much I tried. Then I applied penetrating lubricating oil to it, as I've done with the older ones, and locking it in AGW became again straightforward and easy. The importance of this penetrating lubricant cannot be overestimated. Achieving a steady AGW latch isn't a problem at all, this is what my experiments show. The main problems seem to again revolve around the proper rotor weight and the proper rotor and stator magnetic induction profiles. Until we get them adjusted as they are in the original success is hardly likely, I think. I'm curious what's your rotor's weight?
