0 Members and 50 Guests are viewing this topic.
lwh
Quote from: Omnibus on February 02, 2008, 10:25:07 AM
Here's the soundtrack, converted to mp3.
Wow.  That's the most convincing bit of 'evidence' for me, so far, that you guys really are onto something.  Keep it up, and good luck.
Les.
markdansie
@mramos,
None running...and even if they did they would then face the degaussing issue. However I think what they have all missed is if they call it a smot device is should run...just ask omi.
I witnessed a self starting magnetic motor last year...which could easily run for 10 minutes...appeared to accerate when the stator arm was brought in over the rotor. Had me fooled for 20 minutes. However it eventually slowed down. (You guys would have wet yourself if it was posted on youtube).
As an exercise, can anyone tell me why it might have appeared as a self starter...when indeed it wasnt?
The clues are in the words above.
Mark
Bruce_TPU
Good Morning All,
A long night!   ;)
My Tachometer will be here Wednesday.  I need to confirm what the ear and eyes think they are seeing.  New Rotor was Shipped yesterday.  Base is interchangeable for both.
My Stator / rotor separation is 9 mm.
I am about to order the N38's that Omni has, with the 30.5 mm separation, for the rotor.
Also, Monday, I am going to purchase new ABEC 7 rotor bearings for both rotors.  I replaced my stator bearings, but need to replace the rotor bearings.  Time for precision.
Thanks for the Kudo's guys, but let's hold the champaign, until we replicate Al's.  But I can say it is one of the coolest things I have ever witnessed!   ;D
Cheers All,
Bruce
dean_mcgowan
Quote from: markdansie on February 02, 2008, 12:27:25 PM
@mramos,
Mark
As the stator arm was moved energy was added to the system ... ;)
Another "hand on it" effort
Cheers
Dean
dean_mcgowan
edited...
single slit diffraction posting method damn doubled up me postin' ... grrr
Cheers
Dean
