0 Members and 18 Guests are viewing this topic.
CLaNZeR
Thanks to Oak for some extra pictures.
This one may help abit Jason regards the Axle:
Cheers
Sean.
http://www.overunity.org.uk
robbie47
Quote from: ebswift on January 08, 2008, 06:16:37 AM
Both non-dampened stators should be located in the centre of two of the rotor magnets whilst the dampened stator should be exactly in-between two of the rotor magnets.  The dampened stator would then be exactly in-between the other two stators with a count (inclusive) of three rotor magnets to each non-dampened stator from the dampened stator.
That should be investigated further since Al mentioned following on that at the Steorn forum:
I haven't used the Dremel in a long time, not since the positioning trials for the magnokinetic Judson dampers.
Having in mind that he originally used this setup with 13 stator magnets with the intended holes already in there, Al has obviously tweaked around more on different positions of his dampers.
CLaNZeR
Quote from: rotorhead on January 07, 2008, 10:39:43 PM
Is everyone waiting for magnets?
Just started making the Stator holders this end, but waiting for the magnets :(
CLaNZeR
Quote from: robbie47
A while a go I built a Dremel Rig too spin up Rotors as below.
Now I use an air compressor, less noise and much safer  ;D ;D
sterlinga
http://www.freeenergynews.com/Directory/MagneticMotors/OC_MPMM/BW/SenseCoil.png - "Pic of the sensing coil that was use in some of the testing. Also it give excellent detail of the Judson damper." (B.W.; Jan. 7)
Added to http://peswiki.com/index.php/Directory:OC_MPMM_Magnet_Motor#B.W._Files
http://freeenergynews.com and http://peswiki.com
"The best cutting-edge, clean energy news and directory service on the net."
