dean_mcgowan
Quote from: Tinker on February 03, 2008, 04:34:40 AM
Dean
Based on his postings he "Shut It Down" before he went to bed I wasn't there. His motivations and thought processes were not not made clear to me.
Again do you have any information that you are willing to present that he is not genuine?
TINKER
Can you please post a link to those quotes as I honestly remember it differently and I just cant find it ?
vipond50
Quote from: dean_mcgowan on February 03, 2008, 04:18:52 AM
Bruce,
Nice Vid!
I have sound too.. though i find it hard to perceive the acceleration. Is it at all possible that you can do this by fixing the stators in place with blue tac or something as I can't help but believe you are adding energy into the system (not accusing you of deliberate fakery).
Cheers,
Dean
@Dean
How could he add energy? He did not do any additional movements other than the start up.
hmmm.... maybe he was wiggling his fore finger  :D
Dean.... why don't U construct one of these little beast? Then U can answer all your own q"s
U must be thinking of the Steorn rep video where the guy was oscillating a magnet to induce rotation ?
Joakim
@dean_mcgowan
QuoteI have sound too.. though i find it hard to perceive the acceleration.
I have to agree there. I also have a hard time hearing acceleration - and I've been tinkering with sounds as a hobby for years. I'm however a little bit hopefull that there is something exciting behind all this, although trying to keep my sceptic half alert.  :)
EDIT: Most camcorders have a sound frequency range of approx. 20hz-48.000hz. If one was to use the raw sound (i.e. not these mp3 versions that are embeded in youtube videos) from a recording like this, it should (depending on the level of noise) be quite easy to find any acceleration by loading it into software with a spectrum analysis view of the whole file (Adobe Audition for example). In spectrum view mode the sound coming off one of these things will look like a broad or narrow line (depending on the amount of frequencies the rotor generates), going up if accelerating or down if decelerating - easy peasy.
Jdo300
Hello All,
Just a few words here....
@ All Skeptics,
Look, we are all doing research here, and we are all endeavoring to determine once and for all if Al's device works. While we do this, it is definitely great to have a an objective point of view along with a healthy dose of skepticism. But any time spent bashing Al or this motor has no place here. We've already been discussing this motor for 140 pages and I'm sure that the serious builders here don't want to hear more of this. I'm sure many here will agree with me that we wouldn't even bother spending time and money on this thing if it didin't show any promise whatsoever. I have one of these things sitting on my desk right now, and after some corrections have been made to the rotor disk (which was improperly sized), then I too will post results. Point is that this motor is showing signs of working, and though I definitely maintain a level-headed perspective on it, I'm not going to bash Al for taking the time to show the idea to us. Right or wrong, we will get to the end of this; 'nuff said.
@Bruce,
Great video. but like others mentioned, we can barely hear it (I couldn't and I was trying to listen to it over the phone remember!). I would recommend that you put the camera closer to the setup. Another alternative would be to route the audio input to a computer mic and set that close to the rig with the input volume turned all the way up. Lastly, it would help if you added some sort of visual indicator to the rotor (like a strip of tape) so we can get an idea of how fast it is spinning.
God Bless,
Jason O
markdansie
Dear Sterling,
I think what you are implying is that the 10 minutes of running in the situation you are describing was due to the bringing of the stator magnet into position, serving to sort of spring-load the device, which then eventually dissapated.
This is correct, the kinetic energy required to bring the stator arm in was transfered to rotational energy, then of course once that is used the unit stops. Well done.
However, Al reports to have run his motor for 7 hours continues, at which point he shut it off so he could go to bed.  Also, in Al's situation, the stator magnets are already in place, and once they get in sync with the rotor, they cause the aparatus to ACCELERATE.
No Proof, no independent validation ...just heresay. This would easily be resolved with an independent validation. I have also seen devices accelerate and in every case it could be explained.
At least five people have replicated Al's effect to some degree:
Has any of them got a self runner...lets say runs for a couple of hours, with measured power output, degausing tests???. If it was a straightforward as it appeared on youtube it should be a lot easier. You and I both know a clever engineer who is working on this with no positive results so far. Might I remind you of Perendev, who also had a video on the net with a working motor!!!!
http://peswiki.com/index.php/OS:MPMM:Replications
For these reasons, I don't think your skepticism from your other experience can be tranferred here.
Actually quite the oppersite, I stand by my statement that there is no independently validated self running magnetic motor in existence. I hope there would be so we could test one to see if they degauss. I think you could expand that to experiences...I have had many over the years.
I do encourage people to continue there work, you never know when someone might get lucky.
Furthermore, it may be reason to have hope that your other scenario may be legit after all -- just very early in R&D, with a lot of characterizing and engineering before it will be of practical value.  If I recall correctly, that set-up was quite similar to OC / Al's
Sorry on that count, I cant reveal the details of the setup (NDA) However , I have no doubt it will come to nothing. But I never close the book. But I will admit, it had me fooled for a while (20 mins)
PS dont worry,
I wont be posting here for a while, I seldom do.
Kind Regards
Mark
