mikestocks2006
Hi Jdo300
Nice work,
Just a note to add, as ebswift also pointed out and as alsetalokin posted few days back, and from the actuall device pics,  the stator dumper arrangement on the 13 holes is as follows.
D S D E E S E E E E S E E
where D=dumper, S=stator, E=empty
see also http://www.overunity.com/index.php/topic,3871.135.html
I hope this helps for a more accurate replication.
CLaNZeR
Quote from: sterlinga
http://www.freeenergynews.com/Directory/MagneticMotors/OC_MPMM/BW/SenseCoil.png - "Pic of the sensing coil that was use in some of the testing. Also it give excellent detail of the Judson damper." (B.W.; Jan. 7)
@sterlinga
I have managed to gradually collect a few photo's mainly from people emailing them over from their IE explorer caches LOL !
If you want to take a copy and pop them up on your site then feel free too.
http://www.overunity.org.uk
Cheers
Sean.
Bruce_TPU
@ All
I found this interesting post by Al.  It says a lot. IMHO.
"With rotor magnets installed, stator magnets installed, stator magnets free to move but not spinning, rotor initial rpm 1250, rundown time ~120-125 seconds.
Same as above but with stator magnets (3) spinning gearwise, initial rpm 1250, rundown time ~ 90-100 seconds.
Same as above but with stator magnets removed and far away, initial rotor RPM 1250, rundown time ~ 130-140 seconds.
Same as above but with stator magnets screwed down hard to baseplate, not moveable, initial rotor RPM 1250, rundown time ~110-120 seconds, with a distinctly "coggy" feel and a reversal of direction at the very last revolution.
All 3 stator magnets installed and spinning, 2 gearwise and 1 antigearwise, max rpm and rundown time UNKNOWN."
Omnibus
@btebtzer,
Isn't this exactly the effect that caught our attention, which he discovered by mistake--having two stators turn gearwise whilst the third turning anti-gearwise?
Bruce_TPU
Quote from: Omnibus on January 08, 2008, 01:53:12 PM
@btebtzer,
Of course.   ;)
But I like the details.   ;D
