0 Members and 68 Guests are viewing this topic.
Omnibus
@Yadaraf,
Thanks again for the spectral analysis. When the rotor arrives I'll take proper waves and will post them for analysis. As of now the 1.6kHz frequency seen in @alsetalokin's is missing in my wave at ~400rpm which is outside of my resonance region but within the region where the effect is exhibited in the original. The lower frequencies in my wave also differ from the original although they are of the same order of magnitude as the original. It's interesting to see what Bruce's wave will show.
Yadaraf
Quote from: Omnibus on February 04, 2008, 01:02:49 AM
@Yadaraf,
@Omni, Bruce
You are most welcome, Omni.
Bruce, your audio was very clean -- best yet -- except for some apparent line noise.
I just analyzed the audio in Bruce's 2nd video and oddly [or not] his device also has modes at 63 Hz and 300 Hz (similar to Omni's).  Looks like 63 Hz is line noise in audio source, however, since it appears prominently in the baseline.
For anyone considering these analyses services, please leave a baseline [i.e. no talk, no spinning in your audio].  Also please provide at least 5 seconds of "clean" audio at the RPM to be studied.  Thanks.  Yadaraf Reference Labs, Inc.  ;D
Cheers,  :)
Yada..
Omnibus
@Yadaraf,
That 63Hz was present in the resonance section of my wave and was absent in the section at ~400rpm (outside of the resonance region). Is Bruce's 63Hz also within the resonance area or outside of it? Also, in my resonance part there was a 2kHz peak which is absent in Bruce's wave, correct (@alsetalokin's has 1.6kHz at ~400rpm while mine doesn't show any in the kHz range at ~400rpm)?
vipond50
Hello All to all replicators
Messing tonight and came across another effect. Double to Triple GW rotation.
Ok... Start your rotor with a gentle spin, say 100 to 125 rpm. Note that all the Stator's all doing GW rotation. Now select a stator and flip in the GW rotation. When it catches it will spin at twice to three time(?) the rotation rate of the stators. Do not note any improvements, but still an interest effect.
So this device will allow both AGW and Double GW rotation.
Did a quick check and here's one data set
Rotor speed = 107 rpm ( this is all three stators spinning GW)
Stator speed = 585 rpm (approx)
DGW rotation = 1199 rpm
Give it a test, would be interesting to here what your devices do.
skymovingcloud
Quote from: Charlie_V on January 31, 2008, 05:45:11 PM
I still think that the counter rotating stator magnet was not exactly 120 degrees in alignment with the others.  It looks like it's out of alignment by about 10 degrees to the right in the video.  Maybe it's just an optical illusion, but since nothing else is working, why don't you fellows try moving the counter rotating stator magnet closer to one of the other stators, maybe 10-20 degrees down the circle.
I drew a quick picture to show you what I mean.  I have a feeling that if it's going to work, it will work with this type of arrangement.  Someone atleast try this, or if you have already tried it, what happened?
Thanks,
Charlie
I'm doing some work on Phyllotaxis at the moment, it is intertwined with doubling 1,2,4,8,16... maybe if they are not placed at 120 the magic number might be 137.5 deg (to do with the golden ratio), creating spirals 21 and 34  clockwise and anticlockwise (adjacent fibonacci numbers. Could also be 34, 55 for example). The spirals produce values in groups of threes --that's another reason why this might be relevant: See Marko Rodin vortex math and family number groups 1,4,7 and 2,5,8 3,6,9.
Wishing luck to all you replicators, you might just change the world  ;)
