ezzob
Is it a lot of smoke screens here or? ???
On this link   http://www.overunity.org.uk/  there are Plans for construction
like this        http://www.overunity.org.uk/jdo/Drawings.pdf                                scale 1:1
and like this  http://www.overunity.org.uk/jdo/Rotor_Disk_Template.pdf              scale 1:1
On this plans the rotor is 136mm, what is right?? is it 144mm or not ???
And thats only the rotor, seems that it is more questions then answers.
Regards :)
ezzob
Bruce_TPU
Hey All,
I have got some great personal news tonight!  I now have DSL at my Ranch!!   ;D
That means I can do some live web cam experiments, when I have all of the correct parts in.  If some of you would be interested in tuning in...?
About the links about the Perepiteia, they showed the machine at MIT.  They were very impressed.  Read this:
http://gizmodo.com/353655/perepiteia-perpetual+motion-machine-may-actually-dosomething
@ Rob
Not even a problem.  I will for sure do that for you.
Slowly but surely the correct parts are coming together.  I am very encouraged that when we have precise replications we will see the effect.
I did achieve AGW lock several times last night with someone else's rotor.  (Long story) Mine should be here tomorrow...I hope.
When It arrives, I will do a full measurment of size and weight for all parts and match it to Al's.
Cheers all,
Bruce
Omnibus
@Yadaraf,
Here is a sound sample of the rig with which I saw the initial encouraging results (then with rectangular magnets). The weight of the rotor is 237g (HDPE + cylinder magnets + bearings). Although I've tried it also with N35 and N38 I'm sending you the sample with N42. The strength of the magnets didn't seem to make any difference. Here all three stators are present as well as the two dampers. Unfortunately, I couldn't take the rpm measurements--too many things to take care at once. But the initial rpm are on the order of 370rpm which I determined by spinning it in advance several times. In the sample you can hear that the AGW lock up kicks in after the second trial. Sometimes the AGW can appear right after the first trial, sometimes even several trials cannot achieve it until the rpm go below certain level. Let's see what this sample will show if you feel like analyzing it and then we'll take it from there.
Omnibus
@Bruce_TPU,
That's great to have it broadcast live. Good luck with the experiments.
