0 Members and 23 Guests are viewing this topic.
CLaNZeR
Back home for the weekend this end  ;D
My new 1/2 Stator bearings have arrived, so I know what I will be playing with this weekend :)
Much looser than the RC sealed ones.
Will let you know as usual how it goes.
Cheers
Sean.
http://www.overunity.org.uk
CLaNZeR
Quote from: Yadaraf on February 08, 2008, 02:01:49 AM
Q:  If someone can find out from CLaNZeR if the WMV is an original and not extracted from the FLV, that would help.
Hi Yada
Sorry mate I think the WMV was converted from the youtube FLV.
Al records his originals in .MOV format and searching on my Hard drive I have the originals from Video 2 and Video 3 but not Video 1 :( ,
Cheers
Sean.
crash_uni8
hi everyone i was watching the video again and around 2:09 through 2:11  someone says something... does anyone know what he says?
http://www.youtube.com/watch?v=PIvZJ9xGutI
FunkyJive
Yadaraf wrote:
Quote...because the 2nd harmonic of the power line is quite obvious at 120 Hz.
Hi Yadaraf.
Not wishing to appear overly pedantic  :P but the 120Hz buzz could actually be the dominant fundamental if the hum is the result of a poorly regulated supply, or burst noise from full-wave rectification getting into the amplified mic path. I think that the latter is most likely, particularly as broad-band harmonics of burst noise are evident well into the kHz region, so the only means of filtration is a comb notch filter.
There's not so much envelope power in the higher harmonics though, so I'd guess that heterodyning shouldn't significantly impact upon your spectral analysis - but only a guess though  :)
All the best,
FunkyJive
"Invention has its value, but discovery is priceless"
"Faith from the wealth of negative speculation cannot deny faith from the sparks of promising experimentation"
"A quest of impossible odds is not driven by expectations of what is achievable, but by the certainty of what is not"
"It is not weak minds that perpetrate misconceptions, but strong minds heading in the wrong direction"
"Experimenters seek understanding from achievement, academics seek achievement from understanding, whilst sceptics would seek to deny them both"
"Once the world was flat lest we should fall off. Once man could not fly as he was much heavier than air. And so we arrive at another threshold"
BD Townsend
Yadaraf
Quote from: CLaNZeR on February 08, 2008, 12:13:14 PM
Hi Yada
Cheers
Sean.
CLaNZeR,
Thanks very much.  The fact that Al records MOVs now suggests that the WMV could be from the MOV and not the FLV, in which case the WMV is still better than the FLV.  In comparison, the WMV would not be good if it were extracted from the FLV.  I guess I can convet the FLV to WMV and see what the new WMV looks like.   ;)
New question CLaNZeR:
Q:  Could the WMV on your site have been converted from the MOV?
I mentioned that a spectral analysis of the YouTube video yields different results -- specifically, I can't detect the low frequency acceleration like in the WMV file.  It's possible that if the WMV file were extracted from the FLV file there is a compression artifact near the 120 Hz power line harmonic, which produces the appearance of a 144 Hz tone at 1700 RPM.
Cheers,   :)
Yada..
