0 Members and 49 Guests are viewing this topic.
CLaNZeR
Quote from: Omnibus on January 08, 2008, 05:16:41 PM
@CLaNZeR,
I'm looking at the actual video and it seems the dampers there aren't evenly spaced. Can you please take another look at that video. I may be wrong.
I can see what you are saying, because as we look at the video the left hand side dampner looks closer, but I am sure this is just the video angle.
Checkout this enhanced brighter version.
http://www.youtube.com/watch?v=E2Ck9xC4S44
At first when you look at the base, it looks like there are dash holes on the stator plate between each Stator mount hole, but I am sure this is just a shadow cause by the light.
http://www.overunity.org.uk
vipond50
Awesome Job Jason :D
Thanks for doing all that work, very much appreciated
Omnibus
I don't know, still seems closer. This is a detail, however. We'll see what the truth is when the magnets arrive and we start playing with it.
mikestocks2006
Quote from: CLaNZeR on January 08, 2008, 05:09:41 PM
Quote from: Omnibus on January 08, 2008, 04:55:44 PM
@Jdo300,
Thanks Jason. Great job. I'm still a bit confused about the dampers, though. It appears to me one of the dampers is closer to the stationary magnet than the other. Could you please take another look.
Looking through the many pictures there is a mixture of old and new bases.
The base that was used in the demo seems to be the one below.
This shows there are no extra holes apart from the 13 Stator holes which says to me , maybe the Dampners are indeed in TO-BE Stator holder holes.
In saying this, the reason they are in those holes is confusing as in one of the many threads, AL stated the positioning of the dampners were hit and miss, but he probably meant where in the stator holes.
Hi CLaNZeR,
The dampers are on the 2 of the 13 predrilled holes flanking the stator.
Also see alsetalokin's post
"...And one more time: 6061-T6 extruded aluminum bar stock, machined to the exact dimensions of the stator magnets (except I really did use a 3/16 hole, the magnets are a bit bigger here), spaced and oriented by trial and error, and in my unit, the pre-drilled holes for the stator magnets seemed close enough to the sweet positions so I just used them."
I hope this helps
CLaNZeR
Quote from: mikestocks2006
Thanks Mike
Missed that last line, but seems to clear it up and makes life easier!.
Cheers
Sean.
