0 Members and 60 Guests are viewing this topic.
Yadaraf
Quote from: Omnibus on February 14, 2008, 12:07:38 PM
Quote from: sm0ky2 on February 14, 2008, 12:00:19 PM
Quote from: Omnibus on February 14, 2008, 11:01:54 AM
Quote from: sm0ky2 on February 14, 2008, 10:55:46 AM
@funky
almost any drag or torque that works against the wheels spinning is very bad for this design. your bearings should be as low friction as possible, so that you can spin it with your finger and it goes a long way.
anything less than that is going to work against you in some fashion, so i would try to reduce the
"hard to turn" as much as you can.
That's not obvious judging from @alsetalokin's video and the noises heard therein.
Not obvious from the video when he spun the rotor in gear-mode and it continued for a long time?
you just like to argue dont you omni?
Of course, it's not obvious from the video that the friction is low, as you insist. That substantial noise heard isn't from low friction. That's the point I don't agree with you. The friction must be just right not that it has to be low. Now, what's "just right" that remains to be understood.
Omni, Funky,
Shouldn't we also consider that Al's bearings worked because they were old and slightly worn?
Imagine an old bearing containing several balls whose diameters have eroded over time, creating some space between the balls,  When the old bearing is subjected to a rhythmic flux, it's possible that the balls move back and forth in the race -- in a cluster.  The floating cluster could be considered as another magnet that moves back and forth [concentrically] within the stator.
Omni, your lubricant might help form the floating cluster.
Cheers,   :)
Yada..
Yadaraf
@ Anyone,
Is it possible that the rotating [floating] bearing elements within the stator are producing a Searl (SEG) effect?
Is it possible cylindrical bearing elements would work better than spherical ones (i.e. balls)?
... http://www.youtube.com/watch?v=z8qvSNkiB9M
Cheers,   :)
Yada ..
alsetaIokin
@all
Jokes should not be carried too far. I liked your work, your prototypes, your enthusiasm, but now it's time to stop all the game and open your eyes.
I must admit: my movie was a hoax, a beautiful hoax. A big electic motor was hidden under the table, it was turned on by using a pedal.
There is no free-energy. It doesn't exist. Don't you believe me? I don't care.
@OC
Sorry, mate!
@believers
The facts: I was threaten by some unknown guys, that found my home. Those MIBs took my working machine. Obviously I decided to give up for my sake. :-(
14-02-08 The End.  :-\
MeggerMan
Hi Al,
Thank you for that.
So it was all a hoax......well at least I can go back to the TPU now, no hard feelings.
Not sure what to do with all these magnets and bearings, maybe build the orbo, unless that was faked too. :(
Have you posted this anouncement on the Steorn forum too?
Hope you are well and not too overworked as I know you have been very busy at work.
[edit]Please can you post this to the Steorn or the Fizzix forum just to confirm you are the real Al and not someone who is faking your ID[/edit]
Rob
ken_nyus
Quote from: alsetaIokin on February 14, 2008, 03:40:34 PM
@all
@OC
Sorry, mate!
@believers
No one knows what is really happening, but this post, to me, is from someone who does not speak English as their primary language.
Al's language has always been perfect.
To make this believable, please go to fizzx and post the same thing under Al's id there.
