Jdo300
Quote from: hanker886 on January 08, 2008, 08:10:07 PM
Quote from: Jdo300 on January 08, 2008, 06:58:25 PM
Hi All,
Glad you like the CAD drawings. Just wondering, would anyone who has CNC capability be willing to cut parts out for me if I could buy the supplies and send them to you? I could conceivably do this by hand but I would rather have it done right.
God Bless,
Jason O
Jason,
Let me check with Techshop  We might be able to use the CNC there. Let's talk about it.
Hank
Thanks Hank. I'll take you up on that.
@ Everyone, thanks for the generous offers for help. After I get this first model in my hands and can show that it works, the next step will be to make a more adjustable version (like CLaNZeR's) so we can try out different magnet configurations.
@ Wayne,
I replaced the Template files in the CAD Files post with files containing centerline marks for the holes. Let me know if this helps.
http://www.overunity.com/index.php/topic,3871.msg69004.html#msg69004
God Bless,
Jason O
Bruce_TPU
Hi Jason,
Thank you for the great work with your limited time, on the drawings.
I have ordered my magnets, and will check on those bearings for us, tomorrow.
It won't be long and we will be up and kicking...Oops!  Wrong thread....up and rotating!  LOL   ;D
Cheers,
Bruce
Dom
Hi Guys,
Nice work on the replications so far, here is a few of mine from the past:-
torbays replication...Unsuccessful
http://video.google.com.au/videoplay?docid=5291826833015915174
Effect of aluminium turntable on small magnet rotor:-
http://video.google.com.au/videoplay?docid=5120456679111181820
Kundel magnet motor...Succesful, using two solenoids with timing disk
http://video.google.com.au/videoplay?docid=-1674978842555764354
Some people here will know me from before, I'm going to give this ago, as I have a stack of magnets from my previous projects
they are rectangle mostly, I do have some ring magnets, but ill try with the small rectangle ones first.
Dom
vipond50
Hello Group
The time has come to seek a specification on the Stator bearings
In my Rep I will be hopefully using a bearing of the following specification.
Basic Spec.
ID - 0.25", OD - 0.5", Thk - .125 or Metric equivalent, *Free spin*
Material - 300(316) series Stainless
Application - Bearing going into a magnetic application, so needs to of the Non magnetic type, Operational speed in the order of 4K rpm
Have RFI 's out to various vendors and hope to here from them soon.
Note: I would prefer to have a flange type, but may have to settle for the standard shell.
Was interested in the bearing choices the other replicators are planning on incorporating because i feel this is an critical aspect of the device operation.
This is the reason for this Inquiry and Posting  ;D
Dom
Teflon bearings out of no longer working hard disk drives make great bearings
