JoinTheFun
CLaNZeR
http://www.overunity.org.uk
CLaNZeR
Quote from: JoinTheFun on February 16, 2008, 04:35:45 PM
Here it is, but then large scale, of course...
Been there, done that, as soon as it is under load it stops very quickly, unless you know something we do not?
Cheers
Sean.
Bruce_TPU
Hello all,
I spoke with my bearing guy yesterday, and he has given up.  People will not return emails, or phone calls.
Monday, I will attempt to call and get the information myself.  I will keep trying.
I switched out my N38's for N35's and got much better AGW, with the rotor at high speed.
I am going to order and try some even weaker rotor magnets.  My N35's are better than the N38's and I think weaker is better.
I have posted my latest video.  Enjoy.
http://www.youtube.com/watch?v=EffHs8n6oo0
Cheers,
Bruce
