0 Members and 36 Guests are viewing this topic.
Craigy
got my Geo mags out , and played with that setup. I don?t know if my geos are weak but had a few observations. I constructed a row of 4 x 4 parallel triangles. My setup seemed to work as per clanzers but seemed so weak it couldn?t get it wo work on anything but a flat surface. So different to the smot in that respect.
Any concepts or ideas expressed in this post are intended for the public domain. Free licence is given to reproduce and or modify provided it is for non-profit use. I don't want money, I want overunity!!
sm0ky2
you may have to place the gates close together using GeoMags
im using stacks of round 1/4" neodium magnets, with 1/2" steel ball bearings.
ive varried by 2-5 magnets in the stacks, at different times making the gates.
it doesnt seem to matter, as long as they are all the same length,
but they are considerably stronger than the GeoMags, as i can place the gates a few inches apart and it still goes through with considerable force.
ask
http://adleave.com/joe%20067.jpg
The above pic is a design of a new propulsion system.
It is very simple. Some of you guys may have the access to build and test it.
The principle is space is a magnetic field. If we rotate a fan that is made by superconducting material in a vacuum chamber and keep it below critical temperature, we should have a thrust of magnetic wind.
Maybe that's how UFO's fly around. Because magnetic wind moves no mass, the new motor should be high efficiency
Don't ask me who designed it, show me if it works if you can.
BTW, where is Al? How is he?
whetherman
My enthusiasm has waned.  I was excited by my own experiment going through 3 tri-force gates in either direction, but then I decided I needed to test from outside the entrance repulsion zone.
I setup a very shallow ramp to have a consistent roll on each test. I tried with no gates many times to see how far the bar would roll. Then I put 1, 2, and then 3 gates in the path. The bar would consistently roll to about the same place. It would slow down then speed up at each gate but the net result was the same distance (or less, if it wasn't perfectly centered and would lose energy centering itself).
As a sanity test I made sure that I could place the bar magnet past the repulsive entrance and see the easy gate traversal shown in CLaNZeR's videos. (the bar orientations were all right).
So it seems you get out the energy it took to beat the repulsion keeping you out of the array.  If somebody set up a really long straight array, it would be interesting to see the maximum number of gates traversed.  (competition?)
TheOne
Quote from: ask on February 18, 2008, 07:44:55 PM
What you are talking is more related to the Viktor Schauberger http://peswiki.com/index.php/OS:Klimator:Main_Page ?
