Yadaraf
Quote from: Omnibus on February 19, 2008, 03:22:30 PM
@Yadaraf,
No, that's not mine. I haven't posted on youtube yet. Th only place I'm discussing this experiment so far is here in this forum. I think the video you mention was posted by @!Harvey, if I'm not mistaken, and I don't quite understand what he's up to with it.
Omni,
Sorry if I confused you.  I didn't mean to suggest the video was yours.
I was curious what you thought of the video, and in particular pivoting the stator to accomplish AGW (see 01:20 min mark in vid).
Q:  Compared to "finger-flipping" the stator, doesn't it make more sense to use a pivoting device to achieve AGW rotation?
Cheers,   :)
Yada..
sm0ky2
@ Yada
    Unless you have a method of achieving AGW with all three stators i would recommend removing the other 2, as they are not to your advantage and cause extra drag on the rotor.
Omnibus
@sm0ky2,
I agree but it seems that leaving one extra stator almost diagonally from the driving one helps locking it into AGW.
Yadaraf
Quote from: sm0ky2 on February 19, 2008, 04:13:12 PM
@ Yada
sm0ky2,
What intrigues me about using all three stators is the appearance of speed regulation.  For example, when Al's device was spinning with 3-stators its speed appeared regulated to 425 RPM by "something."  Note that 425 RPM is 7 Hz, or near the first Schumann mode of 7.8 Hz.
Also, recall that the 425 RPM plateau was achieved immediately after AGW -- Al said that the device accelerated slightly and then settled down to 1700 RPM [stator].
I think there is something to be gained by studying the first speed plateau.
Cheers,   :)
Yada..
ezzob
Al
Its time too do what CLaNZeR did, and go forward, and forget the whipmag
i have try both and the Tri-force is simple the best, it works    ;D ;D ;D ;D
