0 Members and 25 Guests are viewing this topic.
Unicron
Quote from: RunningBare on March 06, 2008, 04:59:15 PM
Quote from: Unicron on March 06, 2008, 04:54:46 PM
Whahahaha this is like a bad soap opera!!!!
What did you expect, free energy?  ;)
hehehehe good one lol!!!!
nfeijo
HopeForHumanity
Attention omni-bust (bad joke, jk) and others. I have created a thread for the Violation of CoE talk. Please redirect CoE arguments and comments to this thread. They still must relate to smot and magnet motor stuff...
http://www.overunity.com/index.php/topic,4235.msg80979.html#new
Ron Paul is internet overunity: http://www.youtube.com/watch?v=vXnBZd4nyWk
WE MUST STOP THIS! Free energy is being surpressed because of it!
Bruce_TPU
Quote from: Omnibus on March 06, 2008, 12:17:32 PM
@All,
So, here's an idea @alsetalokin gave which could be reproduced: http://www.youtube.com/swf/l.swf?video_id=m6DiE81UBfs&rel=1&eurl=http%3A//www.steorn.com/forum/comments.php%3FDiscussionID%3D59687%26page%3D43&iurl=http%3A//s2.ytimg.com/vi/m6DiE81UBfs/default.jpg&t=OEgsToPDskK2tvgKHZKYCp600pLV_V1Z
Well done, @Harvey, although that's not what we're looking for (we're looking for the effects seen in the first video which allegedly kick in without any external energy input).
Nevertheless, it will be interesting to make the simple calculation based on the weight of your rotor what energy is needed to keep it running at the rpm seen in the video and compare it with the energy actually spent when driving the piston.
Hi Omni,
If I am not mistaken, Harvey has NO external energy input!!!  The magnets with the south poles up, on the top of his rotor, hit the hall effect sensor above them.  From what I understand, it powers itself!!  We need to confirm this, and if true, would be worthy of replicating.  We need a good little circuit diagram and we are off. Waiting on Al for more detail seems a dead end, IMHO.
@ All
Please review Harveys video... again...
http://www.youtube.com/swf/l.swf?video_id=m6DiE81UBfs&rel=1&eurl=http%3A//fizzx.com/viewtopic.php%3Ft%3D306%26postdays%3D0%26postorder%3Dasc%26start%3D60%26sid%3Dd387485a22fe66dc213eca89e23478f&iurl=http%3A//s2.ytimg.com/vi/m6DiE81UBfs/default.jpg&t=OEgsToPDskKMRpGlANM9ZV8_PNJRXe2N
Thank you!
Bruce
