0 Members and 36 Guests are viewing this topic.
Lakes
I`ve sent an email to the e-magnets website with the specs from the K&J website to see if can provide both the correct rotor and stator magnets thats needed.
I let you know when I get a reply.
CLaNZeR
Quote from: Omnibus on January 09, 2008, 05:02:22 PM
We recently stroke a deal with such company to build their antenna on our property and pay us a monthly rent for that. So, you say, had we found a proper device we could also steal energy from that. But that's stealing (forgive the frank language) while I think what we're working on is producing energy from nothing. Anyway, just a little friendly chit-chat now while waiting for the magnets.  My friend already started the lathing an milling, the magnets and the bearings will arrive soon and it'll be seen shortly what we're facing.
Apparently far back when they first started transmitting TV signals, people found a way of tapping power off it, but the way that the TV stations found out was that the signal was not reaching the whole area that it was meant too reach, this was because the buggers were tapping it for power and draining the signal before it got that far hehe  ;D
So you cannot really call this FREE ENERGY as it is being created from another source anyway.
It is illegal to do this BTW and I would not advise to have a go :)
Take a motor and get it to increase the speed of a Rotor from 1000rpm to 4000 rpm, it will take current to start that motor, it will take current to get it too that 4000rpm speed. That requires energy, but if AL's Rig has found a away of doing it without anything but the magnets then we Defo got something interesting here!
http://www.overunity.org.uk
Bruce_TPU
Hey guys,
Al posted this just today and thought it might help.
"Oh, and the rotor is HDPE, the base is acrylic (perspex or plexiglas) and the stator bearing/magnet holders, and the rotor shaft adapter, are of Delrin.
The stators are held to the base in my unit with austenitic SS socket-head cap screws, #4-40, and a tiny washer for clearance (under the bearing).
(ETA I found plastic screws were too flexible for this purpose.)
Cheers,
Bruce
Omnibus
@btentzer,
Any idea where to order these form or Home Depot will have tons of them?
@CLaNZeR,
Didn't know about the tv companies. Interesting. Now we'll put it in a Faraday cage to prove to the authorities what we already know anyway, that is, that the effect isn't due to tapping into the energy pool of an antenna and therefore it isn't illegal. Nevertheless, I won't be amazed if the government pronounces this particular way of energy production (production of energy from nothing) as illegal if it becomes abundant and people start detaching themselves from the utility companies. You watch.
rotorhead
Everyone still waiting for magnets? Maybe they're out of stock after selling so many for that secret military Black Project?
