0 Members and 37 Guests are viewing this topic.
Craigy
i bought the magnets 30 seconds after watching the video , and saw the video as it was posted LOL , nutters arn?t we. I take Al doesn?t work for kj does he ..?
Any concepts or ideas expressed in this post are intended for the public domain. Free licence is given to reproduce and or modify provided it is for non-profit use. I don't want money, I want overunity!!
Elvis Oswald
Quote from: CLaNZeR on January 09, 2008, 05:15:55 PM
Quote from: Omnibus on January 09, 2008, 05:02:22 PM
We recently stroke a deal with such company to build their antenna on our property and pay us a monthly rent for that. So, you say, had we found a proper device we could also steal energy from that. But that's stealing (forgive the frank language) while I think what we're working on is producing energy from nothing. Anyway, just a little friendly chit-chat now while waiting for the magnets.  My friend already started the lathing an milling, the magnets and the bearings will arrive soon and it'll be seen shortly what we're facing.
Apparently far back when they first started transmitting TV signals, people found a way of tapping power off it, but the way that the TV stations found out was that the signal was not reaching the whole area that it was meant too reach, this was because the buggers were tapping it for power and draining the signal before it got that far hehe  ;D
So you cannot really call this FREE ENERGY as it is being created from another source anyway.
It is illegal to do this BTW and I would not advise to have a go :)
Take a motor and get it to increase the speed of a Rotor from 1000rpm to 4000 rpm, it will take current to start that motor, it will take current to get it too that 4000rpm speed. That requires energy, but if AL's Rig has found a away of doing it without anything but the magnets then we Defo got something interesting here!
hmmm... so the number of radios tuned to a station diminishes the signal?  Doesn't sound right to me...
Craigy
I remember a story of someone lighting their shed back in nazi germany with the power from one of the most powerful transmitters of the time, (Gobels and all that), i thing they were like 10 km away from a megawatt signal. The Chap strung a long wire antenna up between some trees and conected it to earth via a light bulb.
Any way , from what i remember , he ended up shot for it...
Radio recievers do not take energy out , in fact they are more liable to re-radiate the signal recieved.
hydrocontrol
I got my K&J magnetics today. Ordered Monday. Standard shipping. No express. Nice magnets. Got 2 two sizes of ring magnets.. The 1/2x3/16x1/4 (R834DIA) and the 3/4x1/4x3/4 (RC4CDIA). Got a couple of different 1/4 rod ones as well.  It is nice they throw in a sample bag of magnets except they stuck to the other magnets and the bag ripped when i tried to remove. They might prove useful. . Now if I only had a rig to mount it all. Lets see.. Got a $10.00 poly cutting board from WallyWorld. Standard cheap material to used for prototypes. Easy to machine. That should should be big enough for the rotor and base. Got a rod of 6061-t6 aluminum. Got some Pleasure Tool roller skate bearings that should go up to high rpm... Now to convince the machinist that I need to use the shop ;) hummm... Maybe show him the video of the motor. That might work. I'll see if I can get started building tonight...  Later...
Bruce_TPU
Hey Guys,
I spoke with the owner of A & W Bearings and Supply Co.
1-936-564-4810
Ask for Mike Butler
He knows all about the magnet motor and has all the drawings.
Bearings for the Stator Magnets:
Part number = R3
Size is 1/2" OD
3/16" ID
1/8" Thickness
Price is $2.40 each, Package of 10
= $24.40
Steel Bearing
RPM rated:
With Grease 41,000 RPM's
With Oil 48,000 RPM's   ;D
No Seal (Less friction)
Bearing for Rotor Stator
1/2" OD
1/4" ID
1/8" Thickness (times 2.  One on top and one on bottom.)
No Flange
$1.50 each per package of 10 =
$10.50
Same type and rating as above.
For flanged, he is pricing tomorrow.  Shipping is added and is subject to where you live, and how you want it shipped, etc.
Mike is excited about this project.
Cheers,
Bruce
