norman6538
Quote from: Bertoa on July 09, 2017, 06:06:15 PM
Hi Low-Q, the bottom line that nothing can change the law of nature is true for systems.
The law of nature is violated in this pendulum
https://www.youtube.com/watch?v=4FzK2XKQ-74
it swings higher than its dropped point.
Norman
Bertoa
You know better than me that this kind of discussion is going on as long as modern science (and for sure this forum) exists. It is not that I doubt well established physical evidence but under certain conditions a 500kg glider is falling upwards into the sky. This conditions are also scientifically explainable but till about 1900 this was impossible. People on this forum explore certain conditions. I spent 80 euro to build a test setup of a PMM. How stupid is that? Curiosity does even costs people's lives. Low-Q, thank's for your views on this theme. This forum is worth visiting because of geeks who spend time and money to do unconventional stuff. Ok, enough of this...
My next project is a test setup of a permanent magnet amplifier. The goal is to explore the interaction between fast rotating magnet vortexes, torque and movement in different axes. For this device I use 2 the same DC motors connected to a V/A meter so I can measure under all conditions the in- output power in Watt. The actuator wheel is freely movable so I can search for the best result/efficiency in the system.
Low-Q
Well, the pendulum stops. How can that be ::) ?
Vidar
citfta
Quote from: Low-Q on July 10, 2017, 04:57:40 PM
Vidar
It stops because the video is faked.  In order to get the pendulum to swing higher on the left than it started from the board is not vertical.  It is laying back and tilted slightly to the left.  It is obvious that is what is going on because the pendulum only swings back slightly past what should be the bottom of the arc when it should at least go as high as it started if the magnets were actually doing anything.
Low-Q
Yup. I know. The pendulum is already "charged" with magnetic potential. So when the pendulum is raised to its starting point, its potential energy is more than just gravitational.
That also results in a much lower position than the starting point when it returns, because the magnetic potential offsets the pendulum with a few degrees clockwise.
How would this forum be like without competent people like us citfta. LOL  ;D
Quote from: citfta on July 10, 2017, 05:30:09 PM
