0 Members and 49 Guests are viewing this topic.
dean_mcgowan
Hi Al,
Is this in effect a protracted smot ramp? basically climbing until it reaches equilibrium? That would explain the acceleration and many other attributes displayed. If you will... imagine a ball moving up a smot ramp with a harness pulling a cog that is turning a gear that rotates the wheel. I may be wrong in so many ways but it just came to mind and I thought I might ask.
Cheers,
Dean
ken_nyus
Here is the most complete collection of photos that I have seen:
http://www.ospmm.com/whipmag/
The captions were provided by Al.
SoeN
@pablo escobar
Weird, I just want to post these questions No. 1,2 dan 3 to Steorn forum while I'm waiting for approval of my signup... ???
Quote from: pablo escobar on January 10, 2008, 06:22:47 AM
Good Luck Dusty!
I think the WhipMag designation is a little to esoteric.
If Dusty is successful, I respectfully petition to call it the Magnetic Flux Capacitor, or just the Flux Capacitor for short, in honor of AL's insistence that this isn't OU, but is just a novel form of something else, like energy storage....  "Back to the Future" comes to mind.
In addition, does anyone know if AL tried the following?
1.Attempt to  spin the other stators antigearwise instead of stopping them?
2.  Remove one or both of the stalled stators while the device is in sync?
3.  Add other stators to the system? Does it only work with the three?
4.  Instead of using the judsen dampers, increase the load on the rotor with weight or the RC prop?
And if the replicators are successful, as a woo woo piece of experimentation, I suggest adding to the rotor system high temperature superconductors.  Spinning superconductors in a magnetic field are theorized to exhibit anti-gravity properties.
If anyone wants to edit and or repost this on Stoern, be my guest.
PE
txghia58
If it does work (and I hope it does as I have allready ordered magnets myself) would it  not be possible to test if it can pproduce work by place a set of coils over the top of the device.
Are the pdf plans that some on here has allready produced (Sorry I forget your handle) are they to scale ie able to be printed and glued to some plexiglass so that someone with only access to basic tools like a table saw and a drill press could reproduce it??
If so when I make mine I will produce complete step by step construction and assembly instruction and post them on make.com.
Magnet arive on friday and work begins on the construction saturday.
RunningBare
Quote from: txghia58 on January 10, 2008, 09:00:43 AM
It is quite likely that coils will affect the magnetic fields involved, this is why I suggested in another post replacing the dampers with a coil and a load attached, this would give both damping effect and enable load measurement.
