ebswift
Quote from: Charlie_V on January 10, 2008, 04:49:53 PM
I have a question which I'm sure has already been answered.  In the youtube video, when he stops the two magnets and the motor speeds up, I've heard it eventually slows to a stop.  However, what happens if he justs leaves all 3 stators spinning and does nothing, does the device slow down still or does it keep running an unknown amount of time?
Thanks,
Charlie
From what I've gathered from what Al's been saying, it runs for an unknown amount of time, just as it does with the two stators stopped.  It just runs slower.  Further tests may show other differences, but time will tell.
Omnibus
Thanks,
Charlie
That's the big question here. I have remained with the impression that it has carried on at that higher speed for three hours without decelerating and then it has stopped for unknown reason. This is one important thing to be verified after replicating the effect from the video. I wouldn't even stop the two stators, I'd have it, as you mention, with all three stators rotating and will try to monitor the rpm as a function of time till it stops abruptly after the 3 hour run (that's the time @alsetalonkin says it has run for unattended, without external energy supply). I would be impressed if it continues to spin for three hours without external supply, let alone if that spinning would be at constant rate. Any of this would point to OU. Also, in addition to the Faraday cage which I will place the device, to kill all these ridiculous proposals for tapping into extraneous EM fields, I'll mount the rotor first to a DC motor and will run it at 300rpm (the rotation rate when spinning it by hand) and then at 1200rpm (the rotation rate due to the effect). The product of the current and voltage I'd measure in those two cases will give me an indication for the power generated from within, coming out of nothing.
yaz
Another easy to find source for rotor and/or stator bearings are those tiny bearings at the end of a router bit. They're good for up to 25,000 rpm and they sure can take a beating!
Had to replace some last year and they only cost about $2 each. Bought them at the local woodworking store.
Bruce_TPU
I ordered my bearings today.  I chose the flanged ones for the center rotor.  A tad more expensive but probably will be worth it.  Add a few drops of oil and they are good to 48,000 rpm's.  I was already speaking with the bearing guy about future upgrades, and once the unit is actually up and running, we hope to replace all of the bearings, first thing, with precision bearings.  Rated rpm's about 100,000.  It simply means less friction.
But we want to use the same type of everything to start with.  Get it running first, before changing anything!  ;)
Cheers,
Bruce
Omnibus
Can't agree mote. Get it running first. Just curious, how much are those precision bearings?
