0 Members and 47 Guests are viewing this topic.
rotorhead
Quote from: tinu on January 10, 2008, 08:47:24 PM
But if you want to find more, just ask Omnibus politely to show you where is the CoE violation for SMOT ?proved beyond any doubt?. And you?ll see and understand for yourself.
And please do it in the appropriate thread.
Omnibus
Quote from: g4macdad on January 10, 2008, 07:59:43 PM
Omnibus,
Read my post more carefully. I was saying that you are not a zealot or Pharisee. I have seen you get continuously attacked so the defensive attitude is forgivable.
Omnibus is not being attacked.
He just pretends to have a proof that he simply hasn?t. What he does have is a limited understanding of SMOT and a huge ego. But little science indeed. I?d guess his skills are somewhere around to those of a high-school teacher but not a brilliant one. I?d be curious to know about his real credentials?
Anyway, the story is long and this issue is off-topic here. But if you want to find more, just ask Omnibus politely to show you where is the CoE violation for SMOT ?proved beyond any doubt?. And you?ll see and understand for yourself.
Cheers everyone and sorry for deviating from the topic.
Tinu
@tinu, cut it out. Al least learn some physics before going around spewing crap. Get out of this thread. People here are trying to replicate something and not put up with your incoherent ramblings.
Omnibus
@btentzer,
What is great about such ramblings:
QuoteOf course I do not have any data at all past about 3 1/2 hours, and I expect it to be able to run for about 1 day 15 hours, or 39 (say 40) hours, thanks to the math models that have been worked out, and based on my conjecture that there may be as much as 17000 Joules available for momentum change, per run.
Nothing. What momentum change? What 17000 Joules? What math models and conjecture?  Didn?t he just say:
QuoteEvery time I have actually seen it stop, it does so by the "dropping out" of the spinning stator. It seems to run at an almost constant rpm until that happens
or
QuoteBut I can say that the slow linear decay to zero rpm, isn't the way it seems to behave.
This clearly shows that energy is being generated out of no source if what he says in the above two quotes is true.
This person should stick to the technical issues and try to convince us that what we see in the video is real rather than trying to shove down our throats his cowardice in the form of completely ridiculous ?models? and bogus ?conjectures?.
ebswift
Quote from: Omnibus on January 10, 2008, 09:30:57 PM@tinu, cut it out. Al least learn some physics before going around spewing crap. Get out of this thread. People here are trying to replicate something and not put up with your incoherent ramblings.
Of all people to have here as the thread monitor.
Bruce_TPU
@ Jason
Take a look at the bottom shot of this OC sim posted from Al's thread.  Al was commenting on the bottom negative spike.  Does that look to you what I think?  Remember that post of yours along time ago, about the exact same looking negative spike?
Perhaps I am seeing things?   ???
LOL
Let me know what you think.  It is intriguing.
http://www.geocities.com/deasyart/steorn/OC_sim_one_stator_a.JPG
Cheers,
Bruce
