Omnibus
@btentzer,
That's pretty interesting. This is exactly how I imagined @xpenzif's motor would work. Difficult to achieve proper timing, though with the latter motor to have every following station (rotor magnet in this case) in a proper position with respect to the stator, not only to overcome the back drag but also to add some extra energy compared to the previous station. @alsetalonkin has achieved it and I hope we'll achieve it too. It may be that the particular design @alsetalonkin has found out by chance makes this timing issue less of a problem and the device more practical too (more efficiently utilizing said possibility for extra energy at every new magnet).
Motorcoach1
Way to COOL ..OK i'm building hehehe , need a break from the Testanika machine anyway  ;D
amigo
Hello fellow seekers,
I have followed these developments with detached interest but would like to point something out that might not be obvious and it is definitely incorrect in the drawings made by JDO300. Please see the attached images for reference to my writing below.
The letters A, B and C in the images are not equidistant from the center of the rotor, thus the radius as presented in the Drawings.pdf is incorrect. The radius varies and thus creates and ellipse instead of a circle.
I would like to comment on the ellipse now because I feel that the importance of the geometry as a factor is disregarded while in turn it is the most important part of existence and everything in the Universe. When I say geometry I mean non-euclidean hyperbolic geometry, the "organic", geometry of life.
In my humble opinion, in order for this device to work (by mimic-ing nature), or any device for that matter regardless of magnetic, electric, or other forces, it has to be based on vortex, spiraling, hyperbolic geometry. Furthermore, the motion *has*  to be centripetal, imploding (as per Viktor Schauberger) and not centrifugal, exploding one.
In this case the rotor has to virtually spiral downwards, as if it was falling into the vortex created by the motion forward, and thus the equidistant circle arrangement of pegs holding the stator magnets and dampeners is not correct and will not yield desired results. If you exhibit the the attached images you can observe that I have outlined in RED the circle of the stator and marked A, B and C. The distances are not the same between the rotor and the A, B and C points, to me it definitely does not look like a play of shadow, foreshortening of the perspective or anything like that because it's a fairly clear photo.
I would also like to draw attention to point D which I have outlined as a reference point for orientation. The author of the device had failed to mark one side a virtual "north" and so we have to look at some mark (in this case the notch in the rubber leg edge) for reference because of what I said above regarding the geometry, that the orientation of stators and dampeners is elliptical and thus orientation of the entire assembly makes a difference when looking at the photo.
To make matters more complicated the author of the photos had rotated the assembly several times to make it easy for him to make measurements of stators and so when you are looking at each photo you have to know where's "virtual" north in the picture/assembly.
With all above in mind I think it might be useful to go back into author's video and re-trace these points while marking the virtual "north" orientation, for better understanding of the "falling down" into the vortex effect.
I apologize if this was obvious to some (or most people) in which case I beg your pardon for bringing this "non-sense" to your attention. I just felt it would've been (the most) important factor when replicating and troubleshooting operation of this device.
Thanks.
hydrocontrol
QuoteThis clearly shows that energy is being generated out of no source if what he says in the above two quotes is true.
No source. Not true. We are all sitting on a Electric Dynamo called planet Earth. We spin to the east at over a 1000 mph while the molten core spins at a lesser speed. The massive magentic field generated protects us from a lot of harm while at the same time can easily be detected with a simple compass from anywhere on the planet. This magnet motor that is trying to be reproduced could just as easily be tapping and syncing with the Earth's field to run. The magnetic field of the Earth is clearly a viable source of coupling power for this motor to run.
Omnibus
@amigo,
The pictures you've shown don't seem to be from the same motor shown in the video or maybe they just show the motor more clearly and it appears different. The stators are fewer in the video, if nothing else.
