Bruce_TPU
Quote from: Jdo300 on January 11, 2008, 09:17:53 PM
Hi All,
Glad to see some of the users over at the Steorn forum have come over to join us. As of now, I have my magnets for the motor, and Bruce is sending me some bearings for it. Bruce and I are working with another person, Hank to get a single prototype built. Should have the machine work finished sometime early next week, but as I can see, I have a feeling that a lot of you hear may beat us to the punch  ;).
(Snip)
A correction, three prototypes being built.   One for each of us.  ;)
Plus fish oil for the bearings.  (go figure!  LOL  It might be the smelliest motor, but when it works.. hehehe!)
Cheers,
Bruce
sterlinga
Quote from: SoeN on January 11, 2008, 09:19:07 PM
Quote from: sterlinga on January 11, 2008, 08:01:58 PM
A PESWiki user, Chris Wilshaw posted the following comment:
>>> Perpetually Rotating Bar Magnet Arrangement <<<
http://peswiki.com/index.php/Perpetually_Rotating_Bar_Magnet_Arrangement
IMHO and my experience
It's no more or no less the result would be the same as Perendev Device.
Pulling magnetic force on the one side plus Pushing magnetic force on another side equal to zero.
I would guess that this is what a physicist would say about any magnet motor configuration.
http://freeenergynews.com and http://peswiki.com
"The best cutting-edge, clean energy news and directory service on the net."
Grimer
It's nice to see a real engineering drawing for a change.
Sure is  :) . Took me back half a century to sharpening my H pencil on a sanding block.
But you've probably never seen on of those.  ;)
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
hansvonlieven
Quote from: Grimer on January 11, 2008, 10:56:41 PM
Or perhaps scratching India ink with a razorblade of the transparent paper and rubbing the spot with a little soap so you could draw a new line without it running??
Hans von Lieven
Bruce_TPU
 ;D  Wow!
Check out this post of Al's, from the latest test.  I had a feeling those stator's could go a lot faster.
"was able to get a 12-to-1 resonance going. With the unit operating, presumably on the one stator, I spun another stator magnet really fast gearwise, and it caught, and ran very smoothly, I could tell the stator was spinning faster than usual, and I was amazed when the tach confirmed it. 2 examples: rotor 1050, stator GW 12586. Rotor 1040, stator GW 12454."
Cheers,
Bruce
