Bruce_TPU
Quote from: Rosphere on January 12, 2008, 10:20:42 AM
@btentzer,
Hey, what are you doing over here kicking it with the magnet motor guys?  >:(
Get back and finish your TPU before it gets cold!  :D
I can't help myself Mike!  It is the "attraction" to something that might very well be history making.  (every pun intended.)
And get it right, it's, "Kicking it with the TPU guys and rotating it with the magnet guys!"  ;D ;D :D
Actually they are both about rotating magnetic fields, just different ways of doing it.  Or is it?  What makes SM's TPU work?  He doesn't know why.  What makes this work?  Hmmm......
Cheers,
Bruce
CLaNZeR
Quote from: Omnibus on January 12, 2008, 09:56:28 AM
@CLaNZeR,
Thanks for the video. I see your rotor being 199g is lighter than @alsetalonkin's 258g. Could you try turning it first by hand? I wonder if these 1000rpm were imparted by hand or not? Recall, when @alsetalonkin turns it by hand the spin is at ~400rpm. As the things are going here I'll be starting these experiments on Monday, hopefully. Have the magnets already, the bearings will probably arrive today bu the parts won't be ready till Monday.
A quick video showing the difference between hand and air line.
http://www.overunity.org.uk/ocpm/tests/CLaNZeRSRoto1byhandbyairline.wmv
Cheers
Sean
CLaNZeR
Quote from: btentzer
The rotor has only reached speeds below 2K.  The faster the stator magnets spin, the slower the rotor.  Where Al ran two of the stator magnets anti-gear wise, where they both sped up over 12,000 rpm's, the rotor was 1000 rpm.  So I don't think that you need worry about lift off, just yet!  LOL
But we got to plan for the future Bruce hehe, When I pop it in me car it is not gonna go very fast at 1000RPM is it?  ;D ;D ;D ;D
Craigy
hi sean putting more wieght on the rotor makes it easier to sync as the initial braking effect is not as pronounced with 3 times more wieght . i have now put perspex disks above and below to triple the wieght ot plastic rotor and it seems to make sync easier. I am off to turn some stators holders for the magnets i have here and then maybe can do some reverse spins
Any concepts or ideas expressed in this post are intended for the public domain. Free licence is given to reproduce and or modify provided it is for non-profit use. I don't want money, I want overunity!!
Omnibus
@CLaNZeR,
OK, makes sense. Yours is lighter and you get it to spin by hand at over 500rpm (his is around 400rpm with about 120s wind down time). Would you by any chance have a DC motor to mount the rotor on it and measure the current and voltage necessary to have it spin at 550rpm on the one one hand and at, say, 1500rpm on the other. Let's see what the difference in power is. Then we can compare these data with calculated ones based on the moment of inertia of the rotor.
