0 Members and 57 Guests are viewing this topic.
CLaNZeR
Well gawd that was boring filming that LOL  ;D ;D
But from 1000RPM it took 8 minutes 30 seconds to Wind Down.
Here is a Video and if anyone watches the whole of it, you are a sadder man than me  ;D ;D ;D ;D
http://www.overunity.org.uk/ocpm/tests/CLaNZeRS20mmrotor2winddown.wmv
Off too look at Craigy's video :)
Cheers
Sean.
Craigy
Quote from: rotorhead on January 12, 2008, 02:04:09 PM
Quote from: Craigy on January 12, 2008, 01:47:14 PM
Hi all, got my first anti gear spin using the wrong magnets but no sustain or acceleration to report yet
Craigy, the rotor looks a bit small, rotor magnets too close to each other, possibly too long. My tests show best ratio of rotor magnet to stator dia: 1:1 to 1.5:1
Hi There , this is the playing before i get the correct magnets, i have the correct rotor on its way and the correct magnets, besides the stators themselves are 2 small neos drilled into a perspex disk, i am surprised i got anything with those..
Any concepts or ideas expressed in this post are intended for the public domain. Free licence is given to reproduce and or modify provided it is for non-profit use. I don't want money, I want overunity!!
CLaNZeR
Quote from: sterlinga
Are you joking or did you really see some possible anti-gravity effects?  I would think that this alone would be worth serious investigation.  Could you show that by video?  Unsecure the legs, and allow lift-off (with proper teathering and device protections in place).
Sterling
It is because there are holes in the baseplate, the down draft forces it up.
I had this with another Rig in the Summer when it hit 4000RPM and that just had one 40mm hole under the Rotor, but was enough for the down draft too force it upwards.
Grimer
Quote from: RunningBare on January 12, 2008, 02:07:21 PM
Quote from: RunningBare on January 12, 2008, 01:58:56 PM
Quote from: sterlinga on January 12, 2008, 01:54:03 PM
Hi Sean,
Are you joking or did you really see some possible anti-gravity effects?  I would think that this alone would be worth serious investigation.  Could you show that by video?  Unsecure the legs, and allow lift-off (with proper tethering and device protections in place).
Sterling
Ever consider something as simple as down draft?
Oh, I forgot to add low air pressure above the rotor at those high RPMs
But seriously, could someone explain the connection between gravity and magnetism, I see this around these boards quite often, my understanding is that magnetism and gravity only have similar characteristics but they do not interact,
Mmm...Well it could be that the OCAL effect is a manifestation of the polarisation of inertia - which is another way of saying the polarisation of mass since the definition is the same for both. Mass is not a measure of the amount of stuff but a property of stuff. If you increase the velocity of a body the mass increases but the number of protons, etc. the amount of "stuff" remains constant.
Now it is conceivable that if mass is polarised that there will be less seeing the gravitational wind that blows steadily downwards. So its conceivable that the weight of the rotor will decrease.
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
rotorhead
Quote from: Craigy on January 12, 2008, 02:16:29 PM
Got any 1/4" cubes? One of them mounted in center of the stator, poles facing out, might have a chance. Didn't notice any other stators. Are they there?
