0 Members and 84 Guests are viewing this topic.
Craigy
cool stuff sean , starting my base plate today, although am tempted to plug a few of the new magnets into the old model i have..even though the measurements are wrong. The stator holders are they just brass shaft , friction fit to bearing and magnet?
Any concepts or ideas expressed in this post are intended for the public domain. Free licence is given to reproduce and or modify provided it is for non-profit use. I don't want money, I want overunity!!
Grimer
Quote from: Omnibus on January 14, 2008, 12:21:05 PM
The rc helicopter bearings just arrived. However, they look too small--3/16". They arrived in a huge box with no details whatsoever. Can these bearings be used ... Another glitch.
Huge box with no details?  :o
Better check for polonium. ::)
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
CLaNZeR
Quote from: Craigy on January 14, 2008, 01:07:53 PM
Hi Craigy
I lathed down 6mm rod to around 3/16 one end and 3mm the other.
Then I mounted the magnet in the lathe and placed the Brass Rod in the lathe tailstock drill chuck. Then just gently squessed it in. They went in nice and square and a really tight fit.
I cut some 3mm brass tube I had to make the 6mm spacers and the bearings mounted in polycarbonate mounts either side.
On the finished ones press fitted I just threaded the end so I could put a nut on the end and pull fit the shafts into the bearings.
Good luck mate
Cheers
Sean.
http://www.overunity.org.uk
CLaNZeR
Quote from: Grimer on January 14, 2008, 01:08:23 PM
ROFL  ;D ;D ;D ;D
MeggerMan
Hi Sean,
Cracking progress!
800 rpm rotor speed, so you need 4 x that for the sync on the stator, so thats 3200 rpm, I think you'll need some ribs/bumps on the stator to allow it to be spun up to speed with the air line. Bit of a trade of with air resistance.
Could you use the tacho to find the max you can spin the stator at by finger?
The other thing to try is using the brass you have, increase the stator inertia to help the syncing process.
If you make a small flywheel about 12mm or larger out of brass rod, you could drill series of 2mm holes around the circumference to allow the air gun to work.
I think the holes will create only a small amount of drag compared to bumps.
Sorry for all the suggestions.
I brought home two harddisks today with the idea of stripping them for bearings, but it is not that easy. Although I have a set of security torque drivers, some of the hub screws are too tiny even for my set.
[edit]Hi Localjoe, its a old quantum 450Mb drive, I also have a new looking Seagate 40Gb barracuda. There will be more drives I can get at work, just need to keep checking.[/edit]
[Edit 2]alsetalokin is back on the Steorn forum in the last half hour, so he has not gone or been got by the MIBs (sounds painful!) , phew!!!, maybe he can give Sean some pointers now.[/edit 2]
Rob
