0 Members and 45 Guests are viewing this topic.
argona369
Quote from: JAG on January 15, 2008, 12:51:57 AM
Al just posted this at the Steorn Site.
What I've seen look really good, I think people are doing some impressive work, and I hope having some fun too.
I don't have much time
But here are a few tips
First, safety. Safety First!
--do not leave magnets lying around loose, even for a few moments. They are easy to lose control of, and hot flying pieces and pinch hazards are to be taken seriously. I use metal jar lids as magnet trays.
--do NOT grind, burn, etc. these NdBFe magnets! The dust is toxic and otherwise obnoxious, the fumes are toxic and smelly, etc.
--do not rely on adhesives! use structure to retain magnets against fields and forces.
Next, machining acrylic plastic and polycarbonate:
--Use WD-40 or clean kerosene (NOT GASOLINE OR PETROL!) as a cutting lubricant to keep drills, taps and other tooling cool and cutting well. Beware of alcohols--acrylic crazes and loses strength on exposure to alcohol--even the alcohol in a Sharpie marker will craze the acrylic over time, and cracks will occur. Wash the WD-40 off with dishsoap and warm water.
--plastic supply companies sell special drill bits with a sharper tip angle that won't crack or pull though the plastic. They are well worth the price.
--I usually use bottoming taps even when starting, in plastic, I rarely need the plug tap to start a tapped hole. The bottoming tap makes a better thread I think.
On perseverance:
--It took me literally days of spinning and experimenting before I had a hint that something interesting might be happening--the decreased rotor drag that I first noted before the holidays. After that, more days of trial and error and serendipitous mistakes before I even found the AGW rotation modes. By Accident! So don't get discouraged if nothing seems to work--you may not have the right components or something, or it's not put together right. Recall also that about half my magnet-bearing pairs are ineffective.
--I would guess that most people will get decreased drag and increased rundown times if they get the magnets right. But extended run times like I saw are probably a result of some EM interaction that's happening in my apartment and at work. For sure it isn't anything like OU.
Ummm, not OU?
That is a interesting statement that someone would make
only if the knew (for sure) that it wasn?t OU?
sounds like a game to me.
canam101
Ummm, not OU?
It's starting to sound that way to me too. For someone who has invented the greatest thing since fire, he is awfully casual about it.
ken_nyus
Quote from: vipond50 on January 15, 2008, 12:37:19 AM
@Crashuni1
Here's another Drawing of the Rotor Jason did an excellent job, but i alway work up my own so I can do amendments if needed.
Thanks Jason
I guess that is yet another way to interpret the 2.5" spacing of the rotor mags, you take it to mean 2.5" to one of the corners of the octagon, not the flat face.
Jinis
QuoteUmmm, not OU?
Sure NOT OU. Energy comes from the magnets! If we would be able to calculate maximal amount of energy what we can extract from the magnets and the energy extracted by this device, we would see - it should be not OU.  ;D
argona369
Quote from: Jinis on January 15, 2008, 10:24:30 AM
QuoteUmmm, not OU?
Ok, then would he be willing to call it  ?free energy??
Or, is it more conventional say, equal to the degaussing of the magnets.
I.e. ?using up? the energy used to magnetize the magnets.
Over-unity  and free energy are synonyms in my mind,
Which could be argued  endlessly (and pointlessly as well).
