Grimer
Quote from: Jinis on January 15, 2008, 10:24:30 AM
QuoteUmmm, not OU?
Sure NOT OU. Energy comes from the magnets!
The amount of energy magnets have is negligible. If the energy came from the magnets then the magnets would loose their magnetisation. They don't.
The energy comes through the magnets from the surrounding environment, the magnetic potential the magnetic pressure. The magnets are releasing that potential, that pressure like a tap releasing the pressure in the mains.
Jag had the right idea, the right appreciation of things. He wrote:
ooooooooooI have seen energy from permanent magnets! I think I'm going to cry.
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
Grimer
Quote from: argona369 on January 15, 2008, 10:43:34 AM
QuoteUmmm, not OU?
Sure NOT OU. Energy comes from the magnets! If we would be able to calculate maximal amount of energy what we can extract from the magnets and the energy extracted by this device, we would see - it should be not OU.  ;D
Ok, then would he be willing to call it  ?free energy??
Or, is it more conventional say, equal to the degaussing of the magnets.
I.e. ?using up? the energy used to magnetize the magnets.
Over-unity  and free energy are synonyms in my mind,
Which could be argued  endlessly (and pointlessly as well).
The energy comes from a potential source that, till now, we had not learned to tap.
Now we have.
CLaNZeR
Yet another update.
The HDPE 20mm Sheet and Rod arrived today, so have knocked up a Rotor and some new Stator holders:
First I cut the Rod into 16mm lengths.
Then I drilled them out with 6mm all the way through and 12.5mm 6mm deep.
Magnets fitted nice and snug.
Bearings again fitted great.
Next I lathed some 8mm Brass Rods for the shafts.
I threaded the bottoms of the shafts so they can mount on my base using 3mm brass screws.
Next I cut out the 20mm Rotor and weighed it up.
Rotor fitted and Stators all in place.
I am waiting now for some 6mm * 13mm Rod magnets to arrive, but may try the Cubes again, but this time only using 2 on each edge rather than 3.
Cheers
Sean.
http://www.overunity.org.uk
magpower
Looks Real Nice Sean looking forward to results. My Update is mine already and still waiting for Stator magnets. I thought last night but very slow coming for my location. I had 2" rod and what a mess to lathe it down, but did it.
Cheers
Wayne
Craigy
hi sean , built a few more of my mk1 stators using 2 separate 4 x5 neos in a wheel. while they all look identical, i have one of the three that does a AGW spin with a tickle. just bear that in mind wen testing and test all stators for performance, some work better than others lol
Any concepts or ideas expressed in this post are intended for the public domain. Free licence is given to reproduce and or modify provided it is for non-profit use. I don't want money, I want overunity!!
