0 Members and 44 Guests are viewing this topic.
MeggerMan
Hi Jason,
Surely you mean the rotor radius is 2.875 inches giving a rotor diameter of 5.75 inches or 146mm?
(I think everyone knew that anyway, just stating the obvious). ;)
Rob
Jdo300
Quote from: MeggerMan on January 15, 2008, 02:40:52 PM
Hi Jason,
Rob
Oopps. Sorry, Yeah 5.75 inches. I edited the post!
FunkyJive
FWIW, In respect of the bearings used for this project...
Don't overlook "Faraday's Paradox", where even a rotating magnet spinning at the same speed as a metal disc, with the disc intersecting the magnetic field, will still yield potential and therefore oppose the change that induces it (Lenz's law).
These constructions certainly don't bear particular resemblance to those demonstrating Faraday's experiment, although the rapid and significant multi-angular distortions in EM fields (particularly around the diametrically-polarised cylindrical magnets) would inevitably have some impact, albeit to varying degrees. Greater impact would be imposed by greater (metal) bearing width and thickness for example, so one area worthy of review if accurate reproductions persistently and inexplicably fail to sustain rotation   ;)
FunkyJive
"Invention has its value, but discovery is priceless"
"Faith from the wealth of negative speculation cannot deny faith from the sparks of promising experimentation"
"A quest of impossible odds is not driven by expectations of what is achievable, but by the certainty of what is not"
"It is not weak minds that perpetrate misconceptions, but strong minds heading in the wrong direction"
"Experimenters seek understanding from achievement, academics seek achievement from understanding, whilst sceptics would seek to deny them both"
"Once the world was flat lest we should fall off. Once man could not fly as he was much heavier than air. And so we arrive at another threshold"
BD Townsend
abassign
@CLaNZeR
hi,
looking at your last tape and comparing it with that of NikolaTelsa, I have noticed a problem of synchronization of the stator with the rotor magnetes.
I have the suspicion that an important part of the debugging is also the correct synchronization to elevated speed.
I think geometry and intensity of the field of the present magnets of the rotor is important to syncronize the rotor with stator.
It excuses the note and we hope that the things are all right.
b0rg13
... i got the impression after watching the first video in youtube that when he stoped the two smaller round magnets it sounded like a small electric motor kicked in and made the big rotor speed up.... i watched it many times, got the same impression each time. :-\
if you want to get out of the rat race,you have to let go of the cheese.
