FunkyJive
Quote... i got the impression after watching the first video in youtube that when he stoped the two smaller round magnets it sounded like a small electric motor kicked in and made the big rotor speed up.... i watched it many times, got the same impression each time.
Hi b0rg13
Presuming that it was not a faked video, even a pure-magnet motor would doubtless sound or behave like an electrically-powered motor if it were truly developing power and momentum.
Kudos to those trying to prove or dis-prove either way  ;)
All the best,
FunkyJive
"Invention has its value, but discovery is priceless"
"Faith from the wealth of negative speculation cannot deny faith from the sparks of promising experimentation"
"A quest of impossible odds is not driven by expectations of what is achievable, but by the certainty of what is not"
"It is not weak minds that perpetrate misconceptions, but strong minds heading in the wrong direction"
"Experimenters seek understanding from achievement, academics seek achievement from understanding, whilst sceptics would seek to deny them both"
"Once the world was flat lest we should fall off. Once man could not fly as he was much heavier than air. And so we arrive at another threshold"
BD Townsend
dean_mcgowan
.. i get the impression he's a bit of a wiz with the truth (pun intended) ... hehehe
Bruce_TPU
Hi Sean,
Your Stator Magnet Holders are looking very nice!   ;D
The only encouragement I would give, is to keep the top of the Stators to about the bottom of the rotor magnets as we discussed yesterday.  It would probably work above the rotor a hair just as well, but not on the same plane.
Fine tuning will be needed as you are well aware of.
I wish the machine shop milling the three of ours would hurry!  LOL
Warm regards,
Bruce
Grimer
Quote from: Craigy on January 15, 2008, 11:45:12 AM
hi sean , built a few more of my mk1 stators using 2 separate 4 x5 neos in a wheel. while they all look identical, i have one of the three that does a AGW spin with a tickle. just bear that in mind wen testing and test all stators for performance, some work better than others lol
That's interesting Craigy. One of the things I soon learnt in 4 decades of materials research is that there is no such thing as a uniform material and one always has to check for variability. For example a 1% difference in density between concrete samples can make an 8% difference in strength. I believe one of the main reasons people were not able to replicate P&F's cold fusion results is that different batches of palladium have different properties. P&F got lucky with their batch. It may take quite a bit of fiddling about to reproduce Alan's machine - Anyway, congratulations on getting AGW. That is the first step on the road to Rome.
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
sterlinga
Quote from: JAG on January 15, 2008, 07:05:47 AM
posted at the Steorn forum
CommentAuthoroldHorseface CommentTime1 hour ago edited  permalink
I have build a quick and funky new system where I get a short burst of acceleration, then a sustained speed for 10 seconds, then it slows down to stop in 20 seconds.
My stator is the same one from my Lego setup, but my rotor is 12" in diameter with 12 magnets facing outward alternating north-south. (unlike the OCAL system or my last Lego setup)
I think if anyone is getting AGW lock, you got it happening, you just need to reduce friction and tweek your alignment.
As AL said, the distance between rotor and stator is citical and different for every type of system. Anyone building a test jig should make that distance variable.
I am going out to Burbank tomorrow to get more magnets (disc neos) and try some more things.
I have seen energy from permanent magnets! I think I'm going to cry.
Posted at http://peswiki.com/index.php/OS:MPMM:Replications:AuthoroldHorseface
If anyone has contact with this person, could you ask him to post photos, video, contact info?  I'd like to add it to the above page if that's okay.
sterlingda {at} pureenergysystems.com
http://freeenergynews.com and http://peswiki.com
"The best cutting-edge, clean energy news and directory service on the net."
