0 Members and 80 Guests are viewing this topic.
CLaNZeR
Quote from: hydrocontrol on January 15, 2008, 08:47:09 PM
Finally got some shop time. I know it is not an exact replication. Not sure an exact replication is even possible if Al does not even know the strength of his magnets which will make a difference. Only have one more stator to make but with just playing with what I have I have formed a couple of ideas of why it may be working. I am not sure how many of you have played with making PMM. My first one years ago was on a 12 inch round wood circle that was 1 1/2 inch thick. I glued a bunch of steel angle iron pieces to a bunch of radio shaft large rectangular ceramic magnets. I was able to get it to spin with another magnet by hand and only moving it about 1/2 inch. I never figured out a way to replace my hand with a mechanical system. I think that is what these round stator magnets do. They pulse the rotor by rotating. BTW a great way to get it up to speed is with an air compressor wand as some of you have done. I also found it spins better one direction (CCW) then the other (CW). Not sure why.. Lots of playing to do before I get more shop time. At least it is a start..
Good work mate, Your Rig is looking really nice.
Cheers
Sean.
http://www.overunity.org.uk
robbie47
Has anyone seen any update info from Alsetalokin on the Steorn forum lately?
It looks like he left the scene.
Bruce_TPU
Quote from: robbie47 on January 16, 2008, 08:13:41 AM
Considering that there has been no "Steorn forum" until a short time ago, and the fact that the man sleeps and works a full time job, you may not hear from him until tonight or so.
Cheers,
Bruce
Prophmaji
Quote from: Grimer on January 15, 2008, 04:08:39 PM
Quote from: Craigy on January 15, 2008, 11:45:12 AM
hi sean , built a few more of my mk1 stators using 2 separate 4 x5 neos in a wheel. while they all look identical, i have one of the three that does a AGW spin with a tickle. just bear that in mind wen testing and test all stators for performance, some work better than others lol
That's interesting Craigy. One of the things I soon learnt in 4 decades of materials research is that there is no such thing as a uniform material and one always has to check for variability. For example a 1% difference in density between concrete samples can make an 8% difference in strength. I believe one of the main reasons people were not able to replicate P&F's cold fusion results is that different batches of palladium have different properties. P&F got lucky with their batch. It may take quite a bit of fiddling about to reproduce Alan's machine - Anyway, congratulations on getting AGW. That is the first step on the road to Rome.
If you look at the resistive characteristics of ionic fluids, ie, fluid glass, the resistance decreases with higher frequencies (stepping away from DC current into AC current).
to enable OU with Cold fusion, you have to go to the sub-harmonic frequencies (of the main molecular frequencies) that also correlate to the DC-AC resistance curved trace of fluid palladium. Watch for it's ionic polarity as well,  with respects to accurizing the shape of the AC component, as a secondary point for fine tuning. (Bedini, other electrical equivalents, etc) This is due to the fact that the atomic structure itself, is a stabilized gyroscopic vortex in-vortex out..based on intersecting 2-d stress fields that are in oscillation. The 3-d universe is a vectoral resultant of these intersecting fields. Obviously the fields stabilize the atomic structure.
If you head for a DC field/current with the 'loosening/resonant' effect AC field of the correct frequency superimposed upon it, you have your desired overunity.
Basically, it's almost as straightforward as hooking up a sine generator to a DC system and having a slow of sweep of AC running  on top of your DC..and then noting the anomalous points..and then working on those.
Remember, it's an electric universe, so potential counts for more than current, when it comes to temporal aspects and thus localized molecular polarization. You are enacting resonant polarization..into conduction, or egress of energy.
Grimer
It would be very informative to have a video showing the rotor RPM for a stretch  before and after reversal from GW to AGW takes place. If there is such a video, apart form Alan Setalokin's, could someone give me the link, please.  :-*
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
