Thanks to ALL for your help!!
Daniel Pomerlou demonstrates free-energy
Started by Bruce A. Perreault, July 21, 2005, 02:42:28 PM
FreeEnergy
it should all be OPEN SOURCE, the rest is bs! :P
Markus
Hi, all
I have read several books about psychics. There are a few mutualities between Daniel and them. For example their ability to see (energy) fields or flows. Some claim to hear voices from another dimension which give them advice.
It is known that Tesla in his childhood sometimes could hardly see because flashes of light constantly appeared before his eyes. He also claimed that he could develop a machine to the smallest detail in his mind and he knew it would work although he had not built it yet.
Daniel said to an engineer: "It would work if you would think with your heart..". Well, this is also very typical for psychics. Most of them do not really think if it is possible (by the laws pf physics) or not. They just do it and they have faith in it.
I hope this doesn?t sound too crazy.
regards,
Markus
nikola_tesla
Like the most famous person on earth once said " Blessed are those who believe without seeing ".
The presenter has said that if you have the plans to the device to " kick start it " you need to use your faith.
So Daniel seems to be able to feel or see the energy/electric fields and then to somehow use his will
to unleash the power flow. Once it has been kick started it works forever after that.
the device can power anything
with 110 volts and 75 amperes
OR
220 volts and 75 amperes if I remember correctly.
In one demonstration he lit a 200 watt bulb with it and then asked if anyone was a smoker and to come up
in front of the class with a cigarette ... he asked the smoker to lit up the cigarette by putting it between the end of
the light bulb and his connector and it produced the fire for his cigarette.
gast
Quote from: nikola_tesla on August 17, 2005, 06:58:22 AM
with 110 volts and 75 amperes OR 220 volts and 75 amperes if I remember correctly.
What kind of wires he used in his demonstrations for such powerfull energy amounts?
The small wires shown in the uploaded pictures should glow if 8 KW (110 Volt, 75 Amp) flow through them.
Gast
