/ Heat Pump / Refrigeration. Can same overunity concept apply to Eletronics???
Started by larsth, January 18, 2008, 11:35:57 AM
larsth
In mechanical engineering your typical quality heat pump / refrigeration unit is over unity in respect to the physical work put in.
Mechanical Work + Ambient Energy(Heat, fluid as exchange medium)   = Output Energy(Heat, fluid as exchange medium)
No violation of conservation of energy but more energy put out than in.
Note the extraction of ambient energy results in observed cooling
Can one not use this to create a self sustaining loop?
My understanding is that efficiency losses would be too high from a thermal/mechanical system..carnot efficiency etc.
Has or could a similar concept be made using electronics? Electric mediums are far more efficient.
E in   + E ambient (Electric/Magnetic transfer medium)        =  E out (Electric/Magnetic transfer medium)
E out (Electric/Magnetic transfer medium) - E in - E losses  =  Extracted useful electrical energy
Is it out there?
hansvonlieven
It is already there.
Photocells and thermocouples do the same thing by taking ambient energy from the environment.
In mechanics we have waterwheels and wind turbines not to mention sailboats.
In a London museum there is a clock that is powered by changes in barometric pressure. It has been running for over 100 years if my memory does not desert me.
There are many untapped energy sources lying around out there, the trick is to extract meaningful amounts of energy.
Hans von Lieven
larsth
Good examples !!
But don't think I asked the question quite right
Would the following analogy apply?
1. Pump compresses Medium
2. Medium goes through first heat exchanger giving off energy
3. Medium throttled to reduce molecular kinetic energy(temp)
4. Second heat exchanger ambient energy sucked into medium.
1. Apply a directional current to circuit using dynamo with positive end of circut earthed
2. Pass current through capacitor array using static discharge to power secondry circut,  (exchanger 1) (use secondary circut to drive dynamo)
3. Trottle current and somehow nduce positive charge in circuit...could on use a use magnetic field?
4. Earth linkage of circuit thus drawing electrons from atmosphere/ground to create equilibrium (exchanger 2),
(Earth considered part of circut)
neptune
@larsth. A possible extension of this idea would be to make a heat pump type device using solid state electronics using the Seebeck /peltier effects. I am not sure if the low efficiency of these devices would allow overunity with present day devices, but it could be possible in the future.
mapsrg
