DEBATE THREAD
Started by Bruce_TPU, January 19, 2008, 11:07:48 PM
Bruce_TPU
I have started this thread for those of you who have a beef with another.  You can take it over here, and not clutter our threads!
Many Thanks,
Bruce
supersam
thanks bruce,
shutinup, shutinup!!! thanks to all
lol
sam
psychopath
Lets start a debate about the SMOT, since it almost always turns up in other threads.
First discussion starter:
Is is possible to make the ball drop higher than the start position(even if it's 1 mm)?
Second discussion starter:
Does the ball gain any extra energy?
Let these two questions guide you through a heated debate!
hansvonlieven
Quote from: psychopath on January 20, 2008, 12:48:08 AM
Am I allowed to push it with my finger??
Hans von Lieven
supersam
@hanz,
only if you can account for the energy imparted.
lol
sam
ps: i know this is probably not how it is going to be presented in technical mathematical formulas, but that is the way everyone but omnibus sees it. except for the physicists that dare debate him.
