My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
dani1
I think the Bubbler was closed
capacitor70
Today I tried my plasma spark plug with 315V DC but no observable change in blast, it is nearly same as 175V DC previous trials
here is modified circuit, now I dont have any transformer.
You can try this circuit with reduced 1N4007 Diodes
Use resistance of 2 to 10 MOhm, parallel with 6A4 diodes to prevent arcing inside the diode. (Conform resistance value)
I have not tried parallel resistance.
See this link
http://www.powerdesigners.com/InfoWeb/design_center/articles/Diodes/diodes.shtm
Also taken trial on engine, not working.. :( with steam
200W bulb is to reduce surge current.
take care ELECTRICAL HAZARD, do it at your own risk
pablitosax
Hello Capacitor !! ..i?m new in the forum... ;D
Question about your circuit  :
Is the left side of the circuit correct ?...(at the left of the spark plug).These 230 VAC are rectified to DC  , and send via the diodes to a spark plug ...is this a correct idea ?...(you ever have DC over the spark plug)
In another hand ..you have a right side the circuit that send a pulses of high voltage....
But with both sides (left and right) added will obtain a DC with peaks of High voltage..is the idea of the original s1r9a9m9 design ?
22vision
Cap, What kind of spark are you getting with this? I pic would be great!
I have my coil up and running and I have an inverter (I blew up my 555timer inverter circuit) do
to a faulty test board but I do have an in car inverter 110v 750w but I am scared to try it there
not cheep!
22vision
capacitor70
Yes 300 VDC is on plug, when high voltage pulse is given it create plasma channel, plasma have zero resistance it discharges capacitor it makes blast.
Same as previous pictures, No differance
not cheep!
DO NOT RUN DIRECTLY WITH INVERTER, USE SERIES BULB TO PREVENT SURGE CURRENT,
I have shown in this new circuit. I am using 200W bulb in series, if anything shorts it glows and protect your inverter. many times rectifier shorts and blow your inverter,
USE BULB IN SERIES
