My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
pvar06
Hi All,
I have seen the details of this discussion on watercar1978 forum and could not stop my self to read the entire thread. I have gone through the complete thread and watched the video posted in between.
So far i was doing research on booster and made couple of decent booster, which produce 1 lpm at 12 volt 10 Amps. But let me tell you that you people are doing something amazing. I also have a bike and would love to convert it to Water alone. Ofcourse this is a 2 stroke bike but i can arrange a 4 stroke engine.
I am prety weak in electronics but have desire to learn and understand. After reading the entire post I have following doubts:
1. At most of the places it have been mentioned 230 V input. From where the 230 volt will come on the bike? Are you guys planning to use the bike battery to make such voltage?
2. To my understanding the spark pulg has a voltage of around 20 kV. Will it be sufficient for water detonation?
3. Is there any successful attempt for running the engine on the water alone? Specially bike engine.
Even after reading this thread i was thinking to convert the bike on water alone. But was thinking only about the HHO. But after reading this post i am thinking on following lines;
1. Use some attachment like capacitor70 has designed to inject the Hydroxy to the engine. At this attachment we should have a solenoid valve which can be triggered through by passing the current through megnate of the bike. In this arrangement we should try to avoid the waste spark problem i.e. it should give the signal to solenoid valve to open only once in 2 revolution of crank shaft.
2. Convert the bike fuel tank to water tank and water must flow through carburator. This will be injected inside the engine. However the nozzle alteration can be done depending on the first bench test result.
3. Use the ignition coil of car engine. This will have pretty high voltage compared to the motor cycle ignition coil. But ofcourse it will be needing 12 volt hence for the same we can install 2 small 6 volt battery (one is already there) in series to get 12 volt. This additional battery will help in electrolysis process to without complete drain out.
4. Use the spark plug which are used in small engines which runs on Kerosene. Such spark plugs have very stong spark to burn the Kerosene. I have tested out this in 1993, when i have converted the bike to run on Kerosene. In this set up i have started the bike on gasoline and immidiately after starting was converting to run on Kerosene.
5. Timing of the engine should be adjusted byrotating the megnate as suggested by one member, who used to do the same on sports car. I think 5-10 After TDC will be good engough to get desired result.
6. Attemp can be made to seprate Hydrogen from electrolysis process and Daniel Dingel is doing for his water powered car. With this we can get better results with minimum quntity of Hydorgen.
Ofcourse this is not a new thinking because many members have thought on this in the same thread. I was thinking this to avoid any problems related to big circuits and heating problem of these circuits. To my mind at the start of the engine the Hydrogen / Hydroxy will give the boost to the spark of spark plug and helps the water to detonate quickly. But when the engine will be hot then there will not be much problem in water detonation.
So it will be combination of Hydroxy / Hydrogen and Plasma spark. I would love to know the feedback of the experienced group member on the above before making my hands dirty.
With best regards
Praveen
India
rfsimoes
Hi all,
I have almost everything hooked up to replicate cap70 test, but I only have a 2 stroke small 25cc engine, but I only want to test for a very sort period, just to see if it fires up.
But first of all what should be goo results on bench?
For bench setup I will replace the pulse pikup coil, TIP122 and 1n4148 with a switch.
What is to expect when I pulverise water?
I'm thinking about using a plastic syringe, large enough to fit a  plug.
Any thought's?
rfsimoes
capacitor70
See this video, This spark plug go on engine
http://www.youtube.com/watch?v=OjBkqNc0GrQ
Spark plug size is 1 inch diameter, to see the flame take spark plug in sunlight (outside the room) or use video camera...
For test I am using switch, make sure direction of HV +ve must...
Do not short spark tip with water drop, just make it wet...
If you are getting thins kind of result then its time to put it into engine.
I don't know how it behave with two stroke engine.....
Best luck  :), If you are using mains supply be careful, place earthing terminal on engine, It gives electrical shock to any terminal, discharge capacitor and remove plug before touching any part of the engine, capacitor gets charged through earthing terminal take plug out before touching any part..
fell free to ask any questions...
rfsimoes
I will use a UPS that will give me ~170V more or less. I hope this isn't a problem...
I'm an electronics technician, not very skilled, but I live in constant electric shock risk. ;D
rfsimoes
capacitor70
