My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
Super God
As a side note, we should be able to run with extremely lean air fuel mixtures and save a ton of gas at least with the ignition circuit.
>9000
JRHall
Capacitor70, have you heated the head and cylinder on your engine to 180F-200F before trying to start your engine on water?  If so did it improve the results?
rfsimoes
Hi all,
Why are you loosing time with S1r? He has been nothing but a lost of time, staling and not helping.
We are getting results here on this thread. Why flood this thread with s1r true or false coil?
He is not helping and we are getting allot of help here.
Focus people.
So anyway, has anyone tried the new cap70 proposed coil? What were the results?
Newsflash:
I got myself an old Briggs and Stratton 3hp engine to mess up. Here it is:
http://www.youtube.com/watch?v=EEs_XF5IWQY
rfsimoes
happyvalley808
@XBox,
Whats the voltage of the new caps you ordered ?
HV
xbox hacker
IMPORTANT UPDATE!!!!:
Here are some info on the pressure and firing issues.....
I hooked up a Spark Trak Tester to the secondary of my coil. With no pressure it worked ok... ie. i got a visable spark on the testers gap. But when i added a little pressure it was not sparking!! So i added more pressure.. still no sparks..... The i adjusted the gap on the primary side to make it bigger....THE SECONDARY SIDE FIRED!!!! Soo...i thought, ok make the gap smaller and see what happens. The spark on the secondary went out! I was moving the primary gap while it was being fired and the results is...Their is a DIRECT correlation between the 2 gaps for it to work under pressure!!!!!
If i put a standard plug on the secondary, and adjust the primary gap while it is arching, the secondary fires all the time no matter where the primary gap was. But for pressurized chamber tests, the gaps must "dialed-in". I have 3 coils that i made. It was the same for all 3!
coil 1: 40 turns on the secondary and 10 primary (heavy duty transformer wire form a microwave for both)
coil 2: 38 turns on the secondary and 8 primary (heavy duty transformer wire form a microwave for primary and what looks like 28ga for secondary)
coil 3: 20 turns on the secondary and 10 primary (heavy duty transformer wire form a microwave for both)
@happyvalley808:
30kV @ 500pF "Door Knob style"
