My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
tsimonin
Hi... I just want every one to see my experiments with gas on you tube www.youtube.com/tsimonin
xbox hacker
Quote from: goldenequity on August 03, 2008, 03:46:25 AM
Been bouncing between forums and assembling ideas in my head.  ::)
So I'll throw this one out there to "cherry pick" from my favorite concepts
so far.... you never know... until you find out. :)
Ozicell Ball Spark Plug
http://www.energeticforum.com/renewable-energy/2386-ball-spark-plug.html
June 2, 2008 Robert Krupa interview / discusses newest ball-to-ball plug patent
http://www.blogtalkradio.com/kywaterfuelmuseum/2008/06/02/Robert-Krupa
From what i have seen in my plug tests, i think you 2 ball design on top of each other will shoot at 90 degrees....so place than parallel with each other and parallel the tube, and i think your water mist needs to be sparyed at the gap for max effect...in your image its past he gap,  i think you will loses the full effect.
LIKE THIS:
@HV:
I think the ion gun is used for antistatic blow gun...not 100%sure. I fix arcade monitors 30kV all day long...lol And i have been bitten! I did get the doorknow caps....they work fine, but no real noticeable improvement, but i will be doing more tests, i have some other caps comming.....i will test for everyone, they are SUPER CHEAP, if they work i will let everyone know...this way we can be all on the same page!
@resonanceman:
So what do you think about my idea for using Ion Gas to arc the DC? do you think it will work.... this would eleaviate the problem of timing the HV/LV with the sparking of the water......
resonanceman
Quote from: xbox hacker on August 03, 2008, 09:01:41 AM
@resonanceman:
Xbox
SHort answer
I think  it will work ...........I am sure that  if it doesn't work directlly  it can be made to work .
Longer  answer
M\y   design   has the HV  from the ignition  coil  being used  to  power a pump .
The  ignition  coil still controls the timing   I simply   use it to create a pulse  at the right time
My plan  has always been  to  trigger the last   plasma  cycle  using   the  water  pumped by previous  pulses .
I  think  that the  bubbles created by  the ignition  coil  and   LV   in my pump is probably  HHO .
The  HHO  should be  well ionised
After   being in  close proximity  to  quite a few pulses  the remaining  water  should be  well ionised .
I think that just  water  spray  in the  channel  should lower the resistance  enough to  allow an arc to form .
With  ionised  water  it should  be  even easier .
If  the  water  doesn't  trigger  the  arc by itself ......... we might need to drive the   final  circuit   with a waveform  with a HF spike  that would   provide  a small   quick  arc ......just enough  to  ignite  HHO ......  Assuming  the  bubbles  are HHO     once a few of those are hit  by a small arc   you  will have enough plasma  to  start the main  arc .
If  the bubbles  are not HHO .......then we would need to  go back ......and make the  electrodes  in the  pump  larger  and leave a bias  voltage on them between pulses ........to  generate HHO .
gary
capacitor70
Plasma water arc, The flame above the water is hydrogen.....
During plasma test, take video and see it frame by frame many things we miss there..
xbox hacker
Quote from: capacitor70 on August 03, 2008, 11:40:21 AM
My camera SUX!!!!! I need one that is about 120 FPS  :-\
