My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
Hankinator
Quote from: jeeperanthony on May 30, 2008, 10:44:17 PM
I've heard that mixing rubbing alcohol can help get rid of water in your gas tank( by making it more volatile.)  Maybe you could go from gas to water + rubbing alcohol?  I'm pretty new to this stuf with very minimal science background(graduating in a week), so its just a thought.
Alcohol when mixed with Gasoline acts as a "bonding agent" when you have water in your tank...basically gasoline and water do not mix...they can settle apart and do not bond chemically.  The alcohol bonds the water molecules and gas molecules together so the water now gets carried through the system with the rest of the gas and the alcohol.
You see this all the time in the winter when your autoparts store pushes those little bottles of "heat" or gas line antifreeze.  It's just a small bottle of alky.
Good Luck all...very interesting.
Thanks,
Hankinator
Super God
Quote from: jeeperanthony on June 04, 2008, 11:13:56 AM
I don't mean to sound pessimistic, but if you inject water like you do gasoline, won't gas mileage stay the same, but just with water?  From what I understand, we can't really afford to use water like that.
It takes more water to idle the engine than gasoline, hence if you ran it on water you would ge less miles per gallon of water unless you recycled it back into the gas tank.  In which case, mileage would be astronomical because you would just keep reusing the same water until it evaporated.
>9000
jeeperanthony
Wow, I feel dumb.  I forgot that the "waste" is water.
Super God
It's ok, I have my moments too.
>9000
22350
Quote from: suckapunks on May 12, 2008, 09:28:14 PM
supergod.  after learning of this topic a few months back i have been reading as much as i can on the subject including the current camaro replication.  after reading his plans again along with others work i will summarize his concept as utilizing an A/C inverted 120V setup without an electrolytic cell to generate a powerful spark that energizes micron sized water droplets in the chamber which instantly converts the water to thermal explosive energy.  i will come back to this later.
Stan Meyers created a fuel cell that after closer inspection has three primary functions: 1 it electrolyzes water, 2-the gases are ionized using bifilar coils and UV energy (laser) and 3-introduces micron sized water droplets into the piston chamber and then utilizes a potent spark to ignite the contents therein.  He also siphons off electrons to keep the plasma charged.
Herman Anderson created several water cars.  in his latest iteration he produced a specially designed spark plug.  while his latest car ran on H2 and not an electrolytic cell, the big deal about his work was that he developed a hollow cell similar in appearance to Meyers.  at the top he positioned a modified spark plug to generate a potent spark with the electrode running through the center of this tube and residing in the piston chamber.  an inlet port was located in the middle of the tube where H2 gas was introduced and allowed to mix with air on it?s way directly into the piston chamber.  he and Meyers both had direct injection modified spark plug units.  anderson?s unit would allow hydrogen to enter along with ambient air, a fine mist of micron sized water droplets and a spark of up to 70Kv.
now.  to keep this as straightforward as i can about successful water cars in general and this is abbreviated.  the key as it relates to your project is in number 5.
1   electrolysis alone, it seems, is generally accepted as being insufficient to power a combustion engine beyond that of a small lawnmower.  even with a pulse generator to increase production, this appears to be insufficient to power a car motor.
2   hydrogen is a tiny molecule and suffers from having a low mass energy density.  hydrocarbon molecules are huge in comparison and their density is sufficient to move the internal workings of a motor.  hydrogen is so light it cannot do so as effectively.  this is why we hear rumors of hydrogen car conversions feeling like they have less or half power.
3   electromagnetism is a recurring theme in each of the successful water car examples with the exception of ?S1r9a9m9?.  this concept of electromagnetism is important because the ionizing of a gas is creating a plasma.  this conversion to the fourth state of matter creates more deuterium (D2) and a more powerful combustion than standard combustion of gases alone.  deuterium has an added neutron making the atom twice as dense as hydrogen.  plasma is a key element in the process as the added power of the gas now compensates for the lack of production ability of plain electrolysis.
4   ionizing or making hydrogen plasma can be accomplished in several ways, IR, UV, X-ray, microwaves and others.  the key frequency for each method is documented in research briefs around the net.  microwaves were mentioned previously, UV happens around 195nm and above.  the excitation frequency for x-rays, gamma rays, etc i haven?t bothered to investigate as they are not practical for the average Joe to dabble with.
5   the high power spark is necessary to ignite hydrogen and deuterium.  i have come to discover this is also critical for another function utilized by Meyers, Anderson and S1r9a9m9.  the spark is generally in the vicinity of 40-70Kv.  What is important with this detail and why Meyers and Anderson inject water directly into the chamber along with S1r9a9m9 using water exclusively is that the extremely high voltage causes the water to instantly steam and ?explode? although it does not combust.  this process produces an enormous expansion of the water as it heats and it does so with greater force than the combustion of gasoline.
now i mention all this to say, while i'm not familiar with everything this guy S1r9a9m9 has done because his plans are so cryptic and unprofessional, it seems some of his procedures are not necessary today.  in 1999 a guy named bebich was granted a patent for a super spark plug capable of delivering up to 100 volts if i'm not mistaken.  patent number 6,581,581.  this aside, modern manufacturers use high voltage sparks now.  and there is a company you can locate online at www.pulstarplug.com that produces 100kv plugs that may work for you as well.
just wanted to bring this all to your attention and hope it works for you.  give them a try.  if the spark creates the thermal explosive energy needed to run the car, then that's a big deal.  second, if the power isn't so great, you can always add a cell afterwards.  the hydrogen would only help in the combustion process.  but to really get the power you want, you need plasma or charged/ionized gas.  to get this, you need additional energy and there is plenty of reading material out there with the details.
keep us posted dude.  and good luck.
suckapunks
Do you think that this is what is going on with the Dingel (and other philipino) projects on youtube?  They all appear to be using a cell that generates hydrogen and oxygen sparately.
Obviously they are not generating the 200 liter/ min. or so that it would take to run a car.  So, maybe they are generating just enough hydrogen to facilitate the water detonation?
If that were the case, we would probably see some sort of modifications around the spark plug area.  I haven't looked on those videos, but this is the best one for details, that I have seen:
http://www.youtube.com/watch?v=T-xRnDn_WF0&feature=related
Take a look and tell me what you think
p
