My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
Super God
I finally got a video camera...Here is my progress thus far:
http://www.youtube.com/watch?v=c6nj0EU9wbU
>9000
Super God
>9000
e2matrix
Nice!  Interesting about the negative working better on the spark.  Good luck on the next step.
Super God
A major problem once you have the system operating is the corrosion of the engine itself. This will be solved in two ways: first I will use a water mist maker to atomize the water, then I will have tightly spaced electrodes to split some of the water mist into HHO (more surface area when we are dealing with mist than liquid water). The HHO should keep the system dry, if not, we can always put a minute amount of gasoline into the system to eliminate the corrosion issue.  The atomized mist water and HHO combination will be fed into the engine intake.
You can use crystals to obtain HHO too, like was Power To Be is doing in his thread.
>9000
e2matrix
It may not be worth doing for a small test engine (unless you have a use for it like a generator) but you might consider using a ceramic product like Cerma.  I plan on trying it as I'm slowly working toward trying some HHO in a car.  Web site here:
http://cermastore.com/cart1/index.php
