Hydrogen generator through hydrolysis
Started by WiCodeProject, January 26, 2008, 10:11:14 PM
WiCodeProject
Quote from: RunningBare on January 27, 2008, 10:29:49 AM
I'm not sure what the resistance of tap water, distilled water is but if memory serves it's somewhere
around .6 ohms
Tap water has a resistance measured in kilo ohms depending on impurities, distilled water will have a considerably higher resistance in the mega ohms range because it lacks impurities.
Thanks for the reply.
http://www.newton.dep.anl.gov/askasci/phy00/phy00787.htm
http://www.newton.dep.anl.gov/askasci/gen01/gen01783.htm
are a couple of places that answer the question of resistance in ohms of water.
I would prefer to just do my own measurements with my meter..
again I pose the question about what device I'm referring to ?
one
Quote from: WiCodeProject on January 26, 2008, 10:11:14 PM
you can buy at any big box electronics retailer.
Low voltage 1.4-14volts
High current (10-15 amps)
Highly Modulated around 42.8khz
able to handle high resistance of .6 - 8 ohms
again what is something that is capable of this?
I have my answer lets see if ther is anyone out there who agrees
WiCode    It looks to me like you  are talking about an  audio  amp.
gary
hansvonlieven
42.8 KHz is an ultrasonic frequency. It has been bandied around a lot. It was allegedly used by Keely to dissociate water. This is not true. Keely used far more complex vibrations than this.
42.8 KHz works to a degree but is not the complete answer.
Hans von Lieven.
angryScientist
I know the device you are  thinking of. It's a "multiphase rotary transformer."
I've been thinking about it a bit and recognize that since you want to inject this ~42.8kHz freq into a rotary transformer there are a couple of things that could things that could confuse the results. First, the primary coils impedance is going to attenuate your signal to a high degree. There could be a benefit to determining the inductance of your primary and using an appropriate capacitor essentially turn that part of the circuit in to a tuned circuit. Second, the rotary transformer will have a frequency of it's own. You could either filter or ignore the beat-frequencies. Or you could have neither the injected freq or the transformer freq be the ~42.8 your looking for and instead have it be the result of the combination of the two.
That multiphase rotary transformer is what everyone else would call an "automobile alternator."
Oh, and please correct me if I'm wrong.
WiCodeProject
Thank you all Car amp was my answer .. well the way I see it is that an amp can be fed almost any frequency to about 125khz .. now thats not to say that it will come stock with that ability because it will most likely have (lpf)/(hpf) switch that maybe restricts the frequency from
10hz-250hz(lpf)/100hz-30khz(hpf). well why not just bypass those and feed it a specific frequency that you generate on a ?????
tone generator, or even on a peice of sofware on your computer like cooledit which can create bursts of any frequency that you could want..
hook your amp to your anode cathode array in your water container and turn up the volume and pump in some noise until you start making hella hho.. I'm planning on doing some heavy experimenting with this concept. I plan to see if I can generate hho like this, determine if it's a significant amount to run a lawn mower .. throw some vaccum oneway valves on some vaccum tube and replace the fuel line with my hho
being generated. if that works and the mower will run I'll continue on to finding a dinky alternator that is going to provide enough power to run the amp and a little battery that will be ued to kick off the hho making process..if I can get all of this to work and work well I.E. I can mow my yard with the mower because it has sufficient power from the hho that it won't die on the high parts.. I will begin trying it with an old carb'd rustbucket I have out on the farm. I'll be around to see if anyone has put any more thought into this idea and to let you all know what
'if anything' i'm able to come up with..
angry you sure did have part of it  :P
