Examples of TPU in Nature
Started by jeanna, January 27, 2008, 05:23:11 PM
evanlocc
Quote from: scotty1 on February 16, 2008, 06:57:06 PM
Apart from the beads in your eyes...Ed could see shiny things moving all around...I can see them too...The effect is similar to what you see in a CLOUD CHAMBER....where silvery streaks from cosmic rays or other radiations can be seen in an alcahol vapour....
The shiny things move all around like a swarm of flies...and if you look a little sharper you can indeed see the whole sky or cloud boiling, almost like you are looking at the aether..or medium with your naked eye :o
Another way i do it is to look at the top of a wooden fence of tree...and the area around it will be full of shiny streaks and something like a boiling gas..
First you see the beads in your eye....then put them in the foreground and look behind them....then you see the shiny things....put them in the foreground and look behind them and the boiling effect will appear...I do it all the time....even in my car waiting at the lights.... ;D
I have also seen other people post that they could see these things too, and they never knew about Ed's writings...so I told them and showed them the notes, and they agreed that Ed words describe what they could see.
Scotty
Yes! That absolutely true(the above desc.).
"""The shiny things move all around like a swarm of flies...""" but no sighted indoor !
Dam once i thought it was true about that was the blood vessel residue left in eye ball when growing up read from newspaper.
THINK   d o e s   MATTER
sparks
Quote from: acerzw on February 21, 2008, 04:14:46 PM
From the Rodin Coils thread.
A
@Acer
      Rodin's math is the first one I know of that actually shows how different the vector is from the infinitely curved.  Omega and delta pulled out of the mix.  Right in the middle point zero where it belongs.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
bw
After understanding Marko's math I started seeing it in many things.  As example, the sides of a water vortex even has the fingerprint on it.  You can see two lines close to each other squeezing the vortex and a large gap between the next two squeeze lines, just like his math.  The gap is the 369 row or the blank or open area on his coil.  The lines all run the entire length of the vortex and concentrate at the bottom.  The two lines are the reversing circuits in his math or the actual windings in his coil.  I snapped some photos in order to study this easier.  Rodin's number system seems to me like perfection.
sparks
      A hurricane. :o   Cool pictures here.  Big law in physics that works out well for predicting energy paths is that you can not change the velocity of anything only the inertia.  Then potential energy will be exchanged from one inertial frame to another.  So to build a tpu you need to build an inertial frame that will interact with another inertial frame thereby causing a transfer of potential energy from one frame to the other.  The magnetic field is an indication of the inertia of any given inertial frame- both in it's strength and it's relative direction.  The Earth's magnetic field extends 15 Earth radi into the "void" at  somewhere around 10-5 Tesla.  It has a shitload of potential energy/mass and inertia therefore it's magnetic field or electrical inertial field is huge.
   SM's tpu by all accounts of his own and of the builders and detectives here "winds up".  This winding up is addition of inertia to a frame.  Faraday tells us that an electrical potential will develop between two magnetic fields of different strength or relative direction.  So the tpu winds up until there is enough inertia in it's frame that it seperates from mother Earth's inertial frame and emf is generated at the magnetic field interface of the tpu and the Earth.  There needs to be a conductor at this interface that is able to  convert this potential energy donation from the Earth so that both the tpu inertial frame is maintained and  the potential energy converted into usable energy outside of the core winding.  The tpu generator winding needs to be shielded in a manner of speaking.  Like the eye of a hurricane is shielded by circulating air currents.
Don't know the exact mechanics but it sure as hell looks like an electrical vortex generator with collector windings assembled.  I really believe that the kick windings need only to be wrapped around the core winding.  Once the core magnetic field gets beyond the core winding and is now in the collector windings, the magnetic field of the Earth's interface is  where you want it.
Think Legacy
Spread the Love
jeanna
Quote from: bw on February 28, 2008, 10:59:28 PM
How about posting a photo or 2 with a little explanation of each if possible.
It is the reason I started this thread. I was asked to take my photos elsewhere, so here is a great place to post a pic of this water vortex you are describing.
I would personally like to have a look at it - along with your thoughts, of course.
jeanna
@Sparks. Yes, of course, a hurricane
