optic sensor pulse motor
Started by jasonspinmaster, February 01, 2008, 02:53:35 PM
jasonspinmaster
i have placed a 4.7k resistor instead of the 10k, and it is spinning a little faster.
my optic sensor is a OPB876 (N package)
jasonspinmaster
 i do not understand you when you  said that i should try and bypass the diode from the emitter. how do i do this. if i just connect up i wire the transistor over heats, very fast
jasonspinmaster
i have been able to drop the resistance down to a 2.2k resistor not the 4.7k
the battery is at 10.25 volts
placing red pin of meter on base i am getting 0.99volts
from emitter 0.52
collector 12.25 volts
RunningBare
Quote from: jasonspinmaster on February 02, 2008, 01:13:34 PM
Do you have a full diagram of the circuit, I need to know where the diode from the emitter goes?
jasonspinmaster
the diode goes from emitter to negative in the battery
