Thane Heins Perepiteia.
johnnyl
Just a quick request for those testers on here.  After completing a test, can you include a short set of conclusions (which can be just a sentence or two) which indicates that the test results either agree with conventional theory/thinking or disagree with conventional theory/thinking.
I am interested in this thread, but my education is chemistry and this electronics stuff is beyond me.  It would help me a lot if the results are summarized as to why they are normal, strange, important, irrelevant, etc.
Thanks,
Johnny
Groundloop
@johnnyl,
I will not make any conclusions based on any preliminary tests. The only way I will make a statement is if a looped
electronic circuit is charging up the input battery. So if I connect a lead acid battery to my circuit and the
battery goes down in charge then there is nothing special. If the battery charges up then we need at
least three replications of the circuit. If every replicates agree with the result then, and only then, can we
make a statement that a circuit MAY be over unity. Next step would be to get a university to test the circuit.
Groundloop.
johnnyl
Groundloop
Good morning.
My new twin core is now done.
Next step is soldering together the oscillator circuit.
Groundloop.
[EDIT]  PCB done. Added image of circuit.
gyulasun
Quote from: Groundloop on February 09, 2008, 07:22:17 PM
@gyulasun,
Thanks for the link. It seems to me that the yellow/white has a material permeability of 75 and all other colors has a lower permeability.
I think I can safely assume that my green/blue one has a lower permeability. So the green will be the input and oscillator coil. I will make both
the input coil and out coil of two strands of magnet wire. Then I can test the core both "ways".
Groundloop.
Hi Groundloop,
Well,  I did some more search on ferrite toroids and it turns out Ferroxcube ( http://www.ferroxcube.com ) has similar or almost similar color code system like Amidon/Micrometal. This link has a tablet on their materials/codes:
http://sharon.esrac.ele.tue.nl/~on9cvd/E-Inleiding%20en%20overzicht%20ferrieten.htm
So your White/Yellow core can also be their 3E5 material with an initial permeability of around 10000 for toroids so your earlier conclusion of all your other colors have a lower permeability is still valid.  Only the permeability values are higher than that of Amidon:
White/Yellow = 10000  3E5 material
Blue = 2000                3F3  material
Ultramarine = 2300      3C90 material
rgds, Gyula
